Cap'n Krusty
Feb 28 2012, 07:39 PM
OK, you win, I'll drop the price! 55 bucks apiece, you pay the freight! No broken fins, no cracks, no no. I'll make sure yours is marked for your particular engine.
The Cap'n
914ltd
Feb 29 2012, 07:16 AM
Cap'n Great price! Possibly a majority of these have broken fins from using a pry bar to turn the engine. Another balance issue is if they have been disassembled to paint. Brad Mayeur
euro911
Feb 29 2012, 08:52 PM
QUOTE(914ltd @ Feb 29 2012, 05:16 AM)
... Another balance issue is if they have been disassembled to paint. Brad Mayeur
I pulled that stunt -
once ... I couldn't believe all the holes the balance shop had to drill into the back side
ThePaintedMan
Feb 29 2012, 10:44 PM
Yikes! We're not supposed to paint them? Uh oh... What if it was never disassembled but just shot with rustoleum?
euro911
Mar 1 2012, 10:50 AM
It's OK to paint them. The balance problem comes into play when they're disassembled (to bead blast, etc). The pulley and fan units are balanced as a unit and if taken apart, everything must be put back together in the same exact position.
Nie Zu Alt
Mar 12 2012, 03:36 PM
PM Sent
Cap'n Krusty
Nov 20 2012, 06:18 PM
OK. It's nearly the end of the year, and I need this thing to go away. I can't believe nobody here needs a good, unbroken, engine fan. Help me get the barn cleaned out!
The Cap'n
Cap'n Krusty
Apr 30 2013, 01:24 PM
Sold, paid for, and shipped! Thanks! The Cap'n
Cap'n Krusty
Jul 17 2014, 12:54 PM
Came across another one! It's early, takes the triple square bolts. Dirty but intact. $55 and shipping. I DO NOT have the bolts!
tweet
Jul 17 2014, 08:09 PM
QUOTE(euro911 @ Mar 1 2012, 12:50 PM)
How can they be re-balanced? Is there anyone that does this work. Should they be painted and then re-balanced? I have one that is off the engine, but still assembled and another that is apart.
bdstone914
Jul 17 2014, 08:16 PM
QUOTE(tweet @ Jul 17 2014, 07:09 PM)
Try contacting a local engine rebuilder. It is a rotating part just like a flywheel or clutch.
The factory manual might say how close they were balanced. Most of the engine components had loose specs for balancing and variation.
I have to wonder how much balancing affects them having seen fans with thick dirt build up on the fins.
tweet
Jul 17 2014, 08:22 PM
Thanks Bruce. When I originally took it apart, that was my initial thought. The fan I took apart had melted plastic, oxidation and rust. So I figured it just would never work correctly like that. I needed to separate the parts to clean it up. I just always assumed there would be shops that can balance them again. I don't know about shops that drill holes in them though. I guess when the time comes, I'll have to choose carefully and ask a lot of questions.
JStroud
Jul 17 2014, 11:44 PM
Any good machine shop should be able to balance a fan.
Cap'n Krusty
Oct 2 2014, 12:48 PM
ONE left!
The Cap'n
