Plug Wires, what's the best?, stock? magnacore? |
brant |
Sep 15 2004, 04:31 PM
Call me....
I was going to do housework.. but could do white car work if you need? brant |
ArtechnikA |
Sep 15 2004, 04:34 PM
QUOTE(Sammy @ Sep 15 2004, 01:36 PM) I don't like the way the connector feels when it goes onto the dizzy cap... The little round rubber seals that seal the cooling air from leaking out the valve covers are junk on the magnecors. Mine kind of shriveled up... i'm a bit sub-thrilled about the cap fit too, but i always use a Nylon tie-wrap on each tower so i -know- they're not coming out. (and i use a different color on #1, so i don't have to try to remember which one that is...) my plug end airseals are holding up fine, but i have a mere 2,2 and it probably doesn't get as hot, plus it just doesn't get as hot here, and there's less ozone... |
Ferg |
Sep 15 2004, 04:47 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Brant, no worries, i'll play with it tonight, if I get stuck I may call you.
Ferg. |
TimT |
Sep 15 2004, 04:48 PM
You could alway build your own wires.. get the length and fit perfect.
Look HERE you can buy bulk Delphi Packard wire, and all sorts of Beru connectors along with the crimp tools etc.... Years ago (cant believe I can say that) I made wire for my 911 using copper core wire with the stock Beru connectors.. never worried to much about a radio in my 911's (IMG:style_emoticons/default/laugh.gif) I have Magnecores on both my cars, the plug connector seems much more positive than the stock wires.. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:20 PM |
