Official Sasquatch Re Build Thread, Part 2 New Rotary then, new trans, all german turbo |
Mike Bellis |
Mar 4 2012, 09:45 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I started a new thread for the re build of the Turbo wankel project.
Here is a link to the begining. http://www.914world.com/bbs2/index.php?showtopic=113156 With a little help from my Brother and Son, we got the car into the garage and I tore the engine out. It took a little over an hour to pull. The turbo looks ok. It's a little dirty but I can't see any knicks in any blades. Shaft play is minimal and it spins wirh air without drag or noise. I will have to take it apart to find any further signs of damage. As expected, I blew the apex seal of rotor 2. The white specks in the picture is where the seal should be. There is very fine grit in the exhaust port. Rotor 1 looks fine. Time for a rebuild or JDM crap motor. I will have to look at my budget, A rebuild is 2-3 times the cost of a JDM motor. Either way, all the components will bolt on. There is a chance if I go JDM, that I will have to modify the engine brace for different motor mounts. Here's some pics of the package... |
Lennies914 |
Mar 13 2012, 05:41 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Great news Mike.
Are you saying that the apex seal passed through the turbo without causing any damage? If so, not as bad as you anticipated. |
Mike Bellis |
Mar 13 2012, 09:00 PM
Great news Mike. Are you saying that the apex seal passed through the turbo without causing any damage? If so, not as bad as you anticipated. It looks like the carbon apex seals exploded into dusty grit. Anyway, got the adapter,flywheel,clutch on the new motor. Mounted the freshly sealed and painted tranny. Yes, painted... So what... (IMG:style_emoticons/default/biggrin.gif) I plan to get it dry fitted into the car and look at the cross bar mods. I hope to keep both engine mounts on the same cross bar. Looks like it will work and will allow the reuse of the blown motor once it gets rebuilt. Ordered some gaskets and still need a new banjo fitting. I love progress! |
Lo-Fi Version | Time is now: 15th May 2024 - 10:01 PM |
