Official Sasquatch Re Build Thread, Part 2 New Rotary then, new trans, all german turbo |
Mike Bellis |
Mar 4 2012, 09:45 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I started a new thread for the re build of the Turbo wankel project.
Here is a link to the begining. http://www.914world.com/bbs2/index.php?showtopic=113156 With a little help from my Brother and Son, we got the car into the garage and I tore the engine out. It took a little over an hour to pull. The turbo looks ok. It's a little dirty but I can't see any knicks in any blades. Shaft play is minimal and it spins wirh air without drag or noise. I will have to take it apart to find any further signs of damage. As expected, I blew the apex seal of rotor 2. The white specks in the picture is where the seal should be. There is very fine grit in the exhaust port. Rotor 1 looks fine. Time for a rebuild or JDM crap motor. I will have to look at my budget, A rebuild is 2-3 times the cost of a JDM motor. Either way, all the components will bolt on. There is a chance if I go JDM, that I will have to modify the engine brace for different motor mounts. Here's some pics of the package... |
Lennies914 |
May 15 2012, 05:58 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Mike, Have you considered using the pedal assy. from the VW? Could even keep the power brakes.
Mike Bellis |
May 15 2012, 06:08 PM
Mike, Have you considered using the pedal assy. from the VW? Could even keep the power brakes. I am considering it. I could tie front brackets into my roll bar cross tube. The fresh air box would need to be removed or heavily modified. So would the front firewall. Not sure about the power brakes on my 930 calipers. They work great right now. Why fix it? Will most likely mont a master cyl next to the existing brake master. Seems like an easier solution? (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 05:32 PM |
