Official Sasquatch Re Build Thread, Part 2 New Rotary then, new trans, all german turbo |
Mike Bellis |
Mar 4 2012, 09:45 PM
I started a new thread for the re build of the Turbo wankel project.
Here is a link to the begining. http://www.914world.com/bbs2/index.php?showtopic=113156 With a little help from my Brother and Son, we got the car into the garage and I tore the engine out. It took a little over an hour to pull. The turbo looks ok. It's a little dirty but I can't see any knicks in any blades. Shaft play is minimal and it spins wirh air without drag or noise. I will have to take it apart to find any further signs of damage. As expected, I blew the apex seal of rotor 2. The white specks in the picture is where the seal should be. There is very fine grit in the exhaust port. Rotor 1 looks fine. Time for a rebuild or JDM crap motor. I will have to look at my budget, A rebuild is 2-3 times the cost of a JDM motor. Either way, all the components will bolt on. There is a chance if I go JDM, that I will have to modify the engine brace for different motor mounts. Here's some pics of the package... |
Mike Bellis |
Mar 31 2012, 11:18 PM
Got the motor/tranny in. Exhaust on. I had to clearence the turbo down pipe a little to clear the new manifold. Radiator return line replaced; Got damaged while loading onto trailer. Got the lower water pump line macked up to the radiator return line. The upper line remained unchanged.
Now I have to figure put if I'm needing any other little things to get this going. More assembly and pics tomorrow. |
Lo-Fi Version | Time is now: 29th April 2024 - 12:19 PM |
