Official Sasquatch Re Build Thread, Part 2 New Rotary then, new trans, all german turbo |
Mike Bellis |
Mar 4 2012, 09:45 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I started a new thread for the re build of the Turbo wankel project.
Here is a link to the begining. http://www.914world.com/bbs2/index.php?showtopic=113156 With a little help from my Brother and Son, we got the car into the garage and I tore the engine out. It took a little over an hour to pull. The turbo looks ok. It's a little dirty but I can't see any knicks in any blades. Shaft play is minimal and it spins wirh air without drag or noise. I will have to take it apart to find any further signs of damage. As expected, I blew the apex seal of rotor 2. The white specks in the picture is where the seal should be. There is very fine grit in the exhaust port. Rotor 1 looks fine. Time for a rebuild or JDM crap motor. I will have to look at my budget, A rebuild is 2-3 times the cost of a JDM motor. Either way, all the components will bolt on. There is a chance if I go JDM, that I will have to modify the engine brace for different motor mounts. Here's some pics of the package... |
Mike Bellis |
Apr 8 2012, 09:42 PM
Got the Terrycable clutch cable in and the throttle cable finished up. The pedal area gave me a hard time with the accelerator connection. The custom cable end has a set screw for the ball with a cotter pin. Set it and forget it. Setting it was a PITA. But, it will never pop off! Ever! No pics so you just have to imagine my fat ass under the dash. (IMG:style_emoticons/default/barf.gif)
Didn't have as time today due to the holliday. Here's a better pic of the copper transition piece I made. The T is brass with a threaded bung. The 1/2 nipple goes to the heater in the fresh air box. |
Lo-Fi Version | Time is now: 29th April 2024 - 02:08 PM |
