Official Sasquatch Re Build Thread, Part 2 New Rotary then, new trans, all german turbo |
Mike Bellis |
Mar 4 2012, 09:45 PM
I started a new thread for the re build of the Turbo wankel project.
Here is a link to the begining. http://www.914world.com/bbs2/index.php?showtopic=113156 With a little help from my Brother and Son, we got the car into the garage and I tore the engine out. It took a little over an hour to pull. The turbo looks ok. It's a little dirty but I can't see any knicks in any blades. Shaft play is minimal and it spins wirh air without drag or noise. I will have to take it apart to find any further signs of damage. As expected, I blew the apex seal of rotor 2. The white specks in the picture is where the seal should be. There is very fine grit in the exhaust port. Rotor 1 looks fine. Time for a rebuild or JDM crap motor. I will have to look at my budget, A rebuild is 2-3 times the cost of a JDM motor. Either way, all the components will bolt on. There is a chance if I go JDM, that I will have to modify the engine brace for different motor mounts. Here's some pics of the package... |
Rand |
Apr 30 2012, 11:29 PM
It doesn't get any nicer than an LS1.
Too common? Psh. I think you are ready for it. |
Mike Bellis |
Apr 30 2012, 11:34 PM
It doesn't get any nicer than an LS1. Too common? Psh. I think you are ready for it. LS1 is cool but too much $$$ when you price the adapter, ECU, etc... The best LS solution is the smag legal crate motor. Still $8k complete plus $1k for the adapter. At that rate, I might as well go 3.6L. Which would be cool but I really cant afford to fix a Porsche 6. The Audi/WV needs no adapter, is smaller and I can use the factory stuff if I pick up the whole car. It's not the first time I stripped the harness and motor out of a donar car. |
Rand |
Apr 30 2012, 11:40 PM
It doesn't get any nicer than an LS1. Too common? Psh. I think you are ready for it. LS1 is cool but too much $$$ when you price the adapter, ECU, etc... The best LS solution is the smag legal crate motor. Still $8k complete plus $1k for the adapter. At that rate, I might as well go 3.6L. Which would be cool but I really cant afford to fix a Porsche 6. The Audi/WV needs no adapter, is smaller and I can use the factory stuff if I pick up the whole car. It's not the first time I stripped the harness and motor out of a donar car. $9k for a lifetime bulletproof mega powerplant doesn't sound bad. Just sayin... |
Lo-Fi Version | Time is now: 29th April 2024 - 05:43 PM |
