Official Sasquatch Re Build Thread, Part 2 New Rotary then, new trans, all german turbo |
Mike Bellis |
Mar 4 2012, 09:45 PM
I started a new thread for the re build of the Turbo wankel project.
Here is a link to the begining. http://www.914world.com/bbs2/index.php?showtopic=113156 With a little help from my Brother and Son, we got the car into the garage and I tore the engine out. It took a little over an hour to pull. The turbo looks ok. It's a little dirty but I can't see any knicks in any blades. Shaft play is minimal and it spins wirh air without drag or noise. I will have to take it apart to find any further signs of damage. As expected, I blew the apex seal of rotor 2. The white specks in the picture is where the seal should be. There is very fine grit in the exhaust port. Rotor 1 looks fine. Time for a rebuild or JDM crap motor. I will have to look at my budget, A rebuild is 2-3 times the cost of a JDM motor. Either way, all the components will bolt on. There is a chance if I go JDM, that I will have to modify the engine brace for different motor mounts. Here's some pics of the package... |
Mike Bellis |
May 2 2012, 11:12 PM
Look what followed me home today. Can you say donor car???
2000 VW Passat, 1.8 Turbo, 5 Speed, Chipped ECU, SPEC Stage 3 Clutch, bunch more goodies. The guy hit a 1 foot by 3 foot piece of concrete on the freeway at 1am. The right front wheel took most of the blow along with the rocker panel and rear wheel. The bumper and intercooler were also damaged. Engine runs good and is driveable, but the two wheels and tires are wasted! The guy is out of work and sold it to me cheap. Real cheap!!! Some of the interior was sold prior to my purchase. Hence the lawn chair drivers seat. The Plan: strip apart the harness wire by wire and get rid of what I don't need. No biggie, been an electrician for over 20 years. Decide if I want to keep gauges, info display, etc... Install the engine/tranny package. Get it running as is but with my air/water intercooler. Then decide if any other mods are warranted. The engine should be good for 200hp as is. Sell off current engine, ECU, 901, etc... I sold my first blown rotary for $500 yesterday. Who would have thought there was a market for blown engines??? (IMG:style_emoticons/default/WTF.gif) This time I am using the factory VW ECU and components. No custom programming. I may get it tuned once complete and see if there is any more easy hp inside. At least I don't have to invent the wheel on this one. The intake and exhaust on this engine are on the same sides as my current setup. Nice! This is a throttle by wire so the pedal will have to swap too. The clutch master cylinder also. Other than some interior bits, this is a complete car. I should have most everything to pull this off. Goal Have it in running condition by WCR 2013! Is there a record for the most engine swaps for the same car? (IMG:style_emoticons/default/confused24.gif) Stay tuned for part three of my build!!! (IMG:style_emoticons/default/cheer.gif) |
Lo-Fi Version | Time is now: 29th April 2024 - 12:05 PM |
