WTF Early Motor Mounts?, How to Replace and How do you know if the are bad? |
914_teener |
Mar 9 2012, 09:30 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Well .....finally need to replace the trans mounts, clunking on hard shifts and I can visibly see the driver side is cracked.
While I am there....those famous words....I decided to check out the front mounts. I should note that my car mfg date is 01/73 so early 73. Questions are? Are these the early type mounts? Where do the rubber bits go? How would I know if they are bad for this type? See pics Thanks to all as usual..... |
Lo-Fi Version | Time is now: 19th May 2024 - 08:52 AM |
