transmission question |
914noob |
Sep 18 2004, 01:42 AM
Newbie Group: Members Posts: 3 Joined: 12-September 04 From: seattle wa Member No.: 2,742 |
I recently bought my very first 914 a couple month ago, and i was hoping you guys could help me out with a few things. First off, i love this car very much and like it more and more every time i drive it, second, i don't know enough about cars to make her run at the best she can. The transmission recently started to grind when i put it into reverse, first when im not moving, and when downshifting from third to second. Just wondering what you guys would recomend for a person in my position. i Want to get it fixed as quickly as possible, but i only have about 500 dollars to spend. Thanks for all your help, your guys site rocks.
bob91403 |
Sep 18 2004, 03:01 AM
Senior Member Group: Members Posts: 618 Joined: 15-September 04 From: Los Angeles, CA Member No.: 2,763 |
OOH, bad news. Reverse might not be too bad. What year car? I don't know if tailshifters are the same but, with a side shift you can get to 1st and reverse without even removing the transmission. You might get away with just changing a syncro ring. With second gear your talking about a complete dissassembly. It depends on how much damage has been done. Make sure your clutch is adjusted first, your grinding might be a sign of incomplete disengagement. Go to Pelican Parts technical pages for further info.
JoeSharpOld |
Sep 18 2004, 03:08 AM
Does it seem cold to you Group: Members Posts: 361 Joined: 29-April 04 From: Camping in Neverland Member No.: 2,001 |
914noob: Welcome to the Club. Not enough info to tell you just whats up. If you have the time today, some of the guys are gonig to move a car of one of the members. This could be a good oppertunity to meet with the guys in your naborhood. There is some really good 914 people up there and they would be glad to tell you whats-up. I belive the therad is Korejo asking for help to a shell. Check it out.
Joe |
ArtechnikA |
Sep 18 2004, 05:02 AM
QUOTE(914noob @ Sep 17 2004, 11:42 PM) Just wondering what you guys would recomend for a person in my position. buy a Haynes, and read the section on checking clutch pedal freeplay. hint: it's probably *NOT* done the way you'd think it "ought to" be done. clutch adjustments are easy. there's supposed to be a locknut on the cable but they often go astray and without one, the adjustments won't last. if you don't have one, get one. if the clutch -is- adjusted properly, or you adjust it and in a week it's bad again, there are some horrible scenarios but let's check the clutch first. also - make sure you have enough transmission fluid. get a GOOD quality 17mm Allen; either the familiar L-shaped one from the Sears or a VW store, or (my preference) the 1/2" drive socket adapter from Snap-On. or better yet, IMO, borrow one of those and replace the Allen plug with a 19mm hex head plug from a 911... if you are thinking of changing the transmission oil, ALWAYS, ALWAYS remove the fill plug FIRST. |
Bleyseng |
Sep 18 2004, 07:12 AM
Red-Beard |
Sep 18 2004, 07:28 AM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
If it is grinding going into reverse at a standstill, it is either the clutch or the pilot bearing.
If you recently adjusted the clutch and the nuts are still there, then the cable is stretching and getting ready to break. James |
monkeywrench |
Sep 18 2004, 01:20 PM
Member Group: Members Posts: 51 Joined: 27-March 04 From: Long Beach Member No.: 1,854 |
Clutch Cable adjustment is a good place to start. New gear oil helps. and I found getting new trany mounts made a big difference.
Allan |
Sep 18 2004, 07:13 PM
QUOTE(ArtechnikA @ Sep 18 2004, 03:02 AM) if you are thinking of changing the transmission oil, ALWAYS, ALWAYS remove the fill plug FIRST. What happens if you don't? I drained mine today before I dropped the engine but didn't remove the fill plug first. What have I damaged? |
Red-Beard |
Sep 18 2004, 07:32 PM
If you can't get the fill plug out, then you can't re-fill the tranny with oil, which makes it a rather expensive paper weight.
Allan |
Sep 18 2004, 07:36 PM
Okay, that's it? Whew, I can get mine out without any problems.
Dr Evil |
Sep 19 2004, 02:07 AM
If you can get the fill plug out then it wasn't working right to begin with and you need a new tranny (IMG:style_emoticons/default/wink.gif)
Allan |
Sep 19 2004, 08:49 AM
Huh?? (IMG:style_emoticons/default/confused24.gif)
Red-Beard |
Sep 19 2004, 08:55 AM
Mike said it with a (IMG:style_emoticons/default/wink.gif)
He was just joking.... (IMG:style_emoticons/default/icon_bump.gif) |
skline |
Sep 19 2004, 09:04 AM
QUOTE(Red-Beard @ Sep 19 2004, 07:55 AM) Mike said it with a (IMG:style_emoticons/default/wink.gif) He was just joking.... (IMG:style_emoticons/default/icon_bump.gif) Thus his name...........Dr. Evil. Mike, you crack me up. |
Allan |
Sep 19 2004, 09:31 AM
Funny stuff. Now I have to go dig mine out of the dumpster. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 14th May 2024 - 07:31 AM |
