QUOTE(914noob @ Sep 17 2004, 11:42 PM)
Just wondering what you guys would recomend for a person in my position.
buy a Haynes, and read the section on checking clutch pedal freeplay. hint: it's probably *NOT* done the way you'd think it "ought to" be done. clutch adjustments are easy. there's supposed to be a locknut on the cable but they often go astray and without one, the adjustments won't last. if you don't have one, get one.
if the clutch -is- adjusted properly, or you adjust it and in a week it's bad again, there are some horrible scenarios but let's check the clutch first.
also - make sure you have enough transmission fluid. get a GOOD quality 17mm Allen; either the familiar L-shaped one from the Sears or a VW store, or (my preference) the 1/2" drive socket adapter from Snap-On. or better yet, IMO, borrow one of those and replace the Allen plug with a 19mm hex head plug from a 911...
if you are thinking of changing the transmission oil, ALWAYS, ALWAYS remove the fill plug FIRST.
