Any experience with Dellortos?, The ones perpetually on ebay. |
Bob L. |
Mar 11 2012, 03:56 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
HI again,
I have been going back and forth on what to put on my 1.7 for fuel intake I thought I had an FI set lined up but it's not looking good. So... back to the beginning. I am interested in a set of Dellorto drla36's that are listed on ebay. They are always available and look very nicely rebuilt. The listing claims they are bench tested and synchronized. Does anyone here have any experience with them? I think they would be just right for my 1.7 They are in Italy. I'm not sure if that should make me more nervous or not. (IMG:style_emoticons/default/confused24.gif) Any help on this would be appreciated. TIA Bob. |
Jesse |
Mar 11 2012, 04:20 PM
Jesse Group: Members Posts: 149 Joined: 15-February 10 From: Mobile, AL, USA Member No.: 11,363 Region Association: South East States |
thats whats on my 1.7 they do ok
i havent had to mess with them but if i could i would go with FI to cut down on the noise |
pilothyer |
Mar 11 2012, 06:55 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
Bob....If you are concerned about dealing with ALFA1750 in Italy, don't worry. This guy is very good at what he does and is very trustworthy, You will be amazed at the shipping times from Italy to your door. Ask him all the questions you need to before buying....Tell him what you have and ask for recommendations. He is a real Pro and you won't be sorry..........Jerry
Mike Bellis |
Mar 11 2012, 07:05 PM
Syncronized on the bench and on your engine are two different things. They will almost never be the same. I like Dells but don't know anything about those.
McMark |
Mar 11 2012, 07:42 PM
Make sure they have air bypass ports. I've seen side-draft Dellortos that didn't and it means you can't sync the two throats perfectly. Getting carbs synced correctly is huge.
Bob L. |
Mar 11 2012, 10:17 PM
Make sure they have air bypass ports. I've seen side-draft Dellortos that didn't and it means you can't sync the two throats perfectly. Getting carbs synced correctly is huge. They do. The listing refers to them being upgraded to brass, synch'd and set with a drop of paint to hold it. After installation I would have everything on the engine tuned up. I'll ask the vendor about jetting/emulsion tubes. |
monkeyboy |
Mar 13 2012, 02:48 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Bob....If you are concerned about dealing with ALFA1750 in Italy, don't worry. This guy is very good at what he does and is very trustworthy, You will be amazed at the shipping times from Italy to your door. Ask him all the questions you need to before buying....Tell him what you have and ask for recommendations. He is a real Pro and you won't be sorry..........Jerry I second that. I have bought a ton of jets and parts from him for a few projects I have been working on. He is a great seller. I would buy from him any day. |
Lo-Fi Version | Time is now: 10th May 2024 - 12:27 PM |
