Is this where I say F%&$% it and get carbs? |
914itis |
Mar 11 2012, 10:40 PM
after installing my engine, everything works fine, Started it and it started right up. I did't start it for about 3 days working on other things like cv's and replaced the gasket on valve cover. I decided to start it today and set the timing, and it starts and cuts right off, in about 15 seconds. I kept cranking, the more i crank the more it looks like it will not start. check tdc on and dizzy, It looks right. check all plugs.
The only thing i remember playing with was the air mixture screw on the trottle. as it ewas runnoing a few days ago to adjust rpm. after a few adjustments here and there, it starts on the first crank then cuts off, when i keep tryng it feels like it wants to start but not enough fire. I check fuel, i have plenty. I removed the delivery fuel line on the rail, there is plenty coming out. fuel pump runs as it should ,when key is turned on and at cranking. I don't know what else, |
Thestigz06 |
Mar 11 2012, 10:51 PM
Aspiring Jarhead Group: Members Posts: 238 Joined: 22-February 11 From: Temecula, CA Member No.: 12,749 Region Association: Southern California |
Check your fuel pressure. If its too high it will run for a bit before it kicks out. My car did the same thing i opened up the pressure regulator and it ran like a champ after.
914itis |
Mar 11 2012, 10:59 PM
Check your fuel pressure. If its too high it will run for a bit before it kicks out. My car did the same thing i opened up the pressure regulator and it ran like a champ after. Do you have any instruction on how to adjust the fuel pressure if that is the case? |
Thestigz06 |
Mar 11 2012, 11:46 PM
Yeah there should be a bolt sticking out of the regulator, just back it out slightly until it relieves the pressure enough for the motor to run. If you happen to have a fuel pressure gauge the car runs anywhere from 28-32psi if im remembering correctly
Mar 12 2012, 12:09 AM
Resident German Group: Admin Posts: 41,628 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
it starts and cuts right off, in about 15 seconds. Make sure your fuel pump relay is working correctly and check that the socket is clean. (IMG:style_emoticons/default/shades.gif) |
914itis |
Mar 12 2012, 07:18 AM
it starts and cuts right off, in about 15 seconds. Make sure your fuel pump relay is working correctly and check that the socket is clean. (IMG:style_emoticons/default/shades.gif) I put a test light on the fuel pump positive wire and it is shown to be working. the lights comes on when i turn the key, then goes off, then comes back on steady as I crank. that makes me believe that the relay is working correctly.. Correct me if i am wrong! |
914itis |
Mar 12 2012, 07:19 AM
I will be getting a fuel pressure gauge today.
Cairo94507 |
Mar 12 2012, 07:29 AM
Michael Group: Members Posts: 9,741 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Get the FI working. I think once you switch to carbs you will be disappointed (assuming the engine was not rebuilt for carbs).
Mar 12 2012, 08:30 AM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The screw on the throttle body only affects the idle RPM, not the mixture.
--DD |
914itis |
Mar 12 2012, 11:31 AM
I just tested the fuel pressure and it is at 32 . is that 2 pounds too much?
would 2 extra makes that much difference? |
rjames |
Mar 12 2012, 12:00 PM
I'm made of metal Group: Members Posts: 3,928 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
after installing my engine, everything works fine, Started it and it started right up. I did't start it for about 3 days working on other things like cv's and replaced the gasket on valve cover. I decided to start it today and set the timing, and it starts and cuts right off, in about 15 seconds. I kept cranking, the more i crank the more it looks like it will not start. check tdc on and dizzy, It looks right. check all plugs. The only thing i remember playing with was the air mixture screw on the trottle. as it ewas runnoing a few days ago to adjust rpm. after a few adjustments here and there, it starts on the first crank then cuts off, when i keep tryng it feels like it wants to start but not enough fire. I check fuel, i have plenty. I removed the delivery fuel line on the rail, there is plenty coming out. fuel pump runs as it should ,when key is turned on and at cranking. I don't know what else, If you have points, did you adjust them? It's not hard to set the gap wrong. And are you sure the time is set correctly? On my car, the red timing mark was not 27 degrees from TDC as the Haynes manual states, (IIRC) but was really the TDC mark. You can verify your TDS by removing the #1 spark plug and feeling for compression. |
914itis |
Mar 12 2012, 12:34 PM
The points were set as well as the timing, and thee fine was running after. I didn't make any changes.
You are correct, the timing is set at the mark which is not 27 degrees. Again the motor started with these settings and idled for over 10 minutes . As far as I understand it is fine to set the timing like that, then use a timing light to set it at 27 deg with a timing light at 3500 rpm. Is that correct? |
TheCabinetmaker |
Mar 12 2012, 12:41 PM
Now I'm confused Paul. Are you saying the timing is set at TDC and not at 27btdc?
914itis |
Mar 12 2012, 12:56 PM
TheCabinetmaker |
Mar 12 2012, 01:16 PM
Yes, your firing 27 degrees late. no wonder it runs like crap. Remove both distributor vacuum lines and plug them. open throttle to around 3200 rpms (with timing light attached). You will see a web on the fan that is about 3/4"" thick. the notch on the housing should be between that large web and the narrow fin just to the passenger side of it. Hope that makes sense. if not I'll shoot a pic for you.
914itis |
Mar 12 2012, 01:20 PM
Yes, your firing 27 degrees late. no wonder it runs like crap. Remove both distributor vacuum lines and plug them. open throttle to around 3200 rpms (with timing light attached). You will see a web on the fan that is about 3/4"" thick. the notch on the housing should be between that large web and the narrow fin just to the passenger side of it. Hope that makes sense. if not I'll shoot a pic for you. |
914itis |
Mar 12 2012, 01:21 PM
Yes, your firing 27 degrees late. no wonder it runs like crap. Remove both distributor vacuum lines and plug them. open throttle to around 3200 rpms (with timing light attached). You will see a web on the fan that is about 3/4"" thick. the notch on the housing should be between that large web and the narrow fin just to the passenger side of it. Hope that makes sense. if not I'll shoot a pic for you. It's not running at all right now , just starts sometimes and cuts right off, need to get it running before setting the btdc . |
rmital |
Mar 12 2012, 01:29 PM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
Yes, your firing 27 degrees late. no wonder it runs like crap. Remove both distributor vacuum lines and plug them. open throttle to around 3200 rpms (with timing light attached). You will see a web on the fan that is about 3/4"" thick. the notch on the housing should be between that large web and the narrow fin just to the passenger side of it. Hope that makes sense. if not I'll shoot a pic for you. It's not running at all right now , just starts sometimes and cuts right off, need to get it running before setting the btdc . you could always just rotate the dizzy counter clock-wise a little till she starts and stay running just to verify. This would advance the timing to get her running....but finding the mark that Curt was talking about should be easy enough. once found, I usually take a little nail polish and mark the back of the impeller to make the job easier..... |
rjames |
Mar 12 2012, 01:35 PM
If you know where TDC is, Pelican Part's website has a technical article that you can print and cut out a template to measure where 27 degrees is.
TheCabinetmaker |
Mar 12 2012, 01:41 PM
Ray beat me to it and he is correct.
Lo-Fi Version | Time is now: 11th May 2024 - 10:55 AM |
