Someday a build thread; Until then, New Radiator Shroud |
tbox56 |
Mar 12 2012, 01:27 AM
Member Group: Members Posts: 54 Joined: 14-November 04 From: Colorado Member No.: 3,115 |
I finally put some time into my teener this weekend, and built the mount and shroud for new griffin radiator. I still need to cut a hole for the latch, but other than that it is complete.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i44.tinypic.com-3115-1331537271.1.jpg) |
DBCooper |
Mar 12 2012, 05:05 AM
Very nice. You bent those at home?
tbox56 |
Mar 12 2012, 06:07 PM
914.SBC |
Mar 12 2012, 06:30 PM
Member Group: Members Posts: 248 Joined: 12-December 10 From: CORONA, CA Member No.: 12,479 Region Association: None |
I love it...
NIcely shaped, etc. (IMG:style_emoticons/default/beerchug.gif) |
firstknight13 |
Mar 12 2012, 08:25 PM
Senior Member Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 |
I finally put some time into my teener this weekend, and built the mount and shroud for new griffin radiator. I still need to cut a hole for the latch, but other than that it is complete. (IMG:http://www.914world.com/bbs2/uploads_offsite/i44.tinypic.com-3115-1331537271.1.jpg) why is the bleeder on top ?.....is it a closed radiator?? very nice... (IMG:style_emoticons/default/biggrin.gif) |
Rand |
Mar 12 2012, 08:27 PM
Did I miss the thread on your build that tells about the power plant?
Hoping you'll point me to it or spill the beans. (IMG:style_emoticons/default/wink.gif) Nice metalwork. |
tbox56 |
Mar 13 2012, 12:07 AM
Did I miss the thread on your build that tells about the power plant? Hoping you'll point me to it or spill the beans. (IMG:style_emoticons/default/wink.gif) Nice metalwork. You didn't miss anything recently, but there might be an old thread somewhere. It is a 2.5l SOHC Subaru engine, naturally aspirated. I am also doing all the body work and paint, adding a set of 916 bumpers, sway bars, and a fresh interior. Should be a sweet ride when it is all said and done. |
Zaney |
Mar 13 2012, 10:16 AM
Deuchland en der Haus Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest |
Looks great!
I am in the final stages of my Suby build too. I will watch yours for the body and paint part. Good luck! Cheers! (IMG:style_emoticons/default/beerchug.gif) Nate |
Andyrew |
Mar 13 2012, 10:33 AM
I finally put some time into my teener this weekend, and built the mount and shroud for new griffin radiator. I still need to cut a hole for the latch, but other than that it is complete. (IMG:http://www.914world.com/bbs2/uploads_offsite/i44.tinypic.com-3115-1331537271.1.jpg) why is the bleeder on top ?.....is it a closed radiator?? very nice... (IMG:style_emoticons/default/biggrin.gif) Because he's smart (IMG:style_emoticons/default/smile.gif) You need a bleeder at the highest points, At the front and the fill in the back are the best spots. |
pete |
Mar 13 2012, 02:19 PM
Member Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States |
Nice sheet metal work. I'm assuming the radiator mounts are just as nice. Do you have pics of the complete installation? What radiator did you use as I need to start sourcing cooling items for my V8 installation.
Pete |
tbox56 |
Mar 13 2012, 06:24 PM
why is the bleeder on top ?.....is it a closed radiator?? very nice... (IMG:style_emoticons/default/biggrin.gif) It is a closed radiator, with no pressure valve up front. That is in the back, and as stated bleeders on each end are recommended. And it came that way (IMG:style_emoticons/default/smile.gif) Nice sheet metal work. I'm assuming the radiator mounts are just as nice. Do you have pics of the complete installation? What radiator did you use as I need to start sourcing cooling items for my V8 installation. The mount and shroud is actually one in the same. there are 4 bolts that go through behind the front bumper, and if I feel it is necessary, i can run a couple through the trunk floor as well. The radiator is from Griffin Radiators, found here. I used the 13x22" with the inlet and outlet positioned for my system. It was a little pricy, but very nice, well built, and couldn't fit better. |
firstknight13 |
Mar 13 2012, 11:54 PM
I finally put some time into my teener this weekend, and built the mount and shroud for new griffin radiator. I still need to cut a hole for the latch, but other than that it is complete. (IMG:http://www.914world.com/bbs2/uploads_offsite/i44.tinypic.com-3115-1331537271.1.jpg) why is the bleeder on top ?.....is it a closed radiator?? very nice... (IMG:style_emoticons/default/biggrin.gif) Because he's smart (IMG:style_emoticons/default/smile.gif) You need a bleeder at the highest points, At the front and the fill in the back are the best spots. i have a griffin radiator and the bleeder is at the bottom but the filler is at the top so i'm wondering if he put the radiator in upside down on purpose with the filler down or if he doesn't have a filler as i do.....i am very much aware of the problems with bleeding the system.... |
Andyrew |
Mar 14 2012, 01:10 AM
The highest point is engine bay. Your fill and overflow should be in the engine bay..
Lo-Fi Version | Time is now: 13th May 2024 - 02:29 PM |
