QUOTE(firstknight13 @ Mar 12 2012, 07:25 PM)
why is the bleeder on top ?.....is it a closed radiator?? very nice...
It is a closed radiator, with no pressure valve up front. That is in the back, and as stated bleeders on each end are recommended. And it came that way
QUOTE(pete @ Mar 13 2012, 12:19 PM)
Nice sheet metal work. I'm assuming the radiator mounts are just as nice. Do you have pics of the complete installation? What radiator did you use as I need to start sourcing cooling items for my V8 installation.
The mount and shroud is actually one in the same. there are 4 bolts that go through behind the front bumper, and if I feel it is necessary, i can run a couple through the trunk floor as well.
The radiator is from Griffin Radiators, found
here. I used the 13x22" with the inlet and outlet positioned for my system. It was a little pricy, but very nice, well built, and couldn't fit better.
