Fuel Tank Return Port, Rubber plug? Help. |
Eric_Shea |
Mar 12 2012, 08:08 PM
Is anyone familiar with this?
I'm attempting to install the fittings for the send and return ports and I'm finding a conical rubber stopper in the return port. Is this suppose to be there? It's inconceivable that someone reached into the tank and put it there so I'm imagining there's a reason for it's existence. Currently I can't imagine what that reason is. Anyone? (IMG:style_emoticons/default/confused24.gif) |
Krieger |
Mar 12 2012, 08:33 PM
Advanced Member Group: Members Posts: 4,707 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
It is not April fools yet Eric.
Mar 12 2012, 08:38 PM
Eric_Shea |
Mar 12 2012, 11:16 PM
I think I figured it out and, why I couldn't get it to operate. This basically plugs the fuel return line. I was using air against it and, air compresses. As a fluid pushes against it, this should flex up enough to let the fluid back into the tank but, not allow the fluid to return out to the pump through the return line.
Pretty ingenious little tool if that is indeed how it works. Someone with their tank out have a look cause these bone heads think I've been torquing one up! (IMG:style_emoticons/default/biggrin.gif) |
914itis |
Mar 12 2012, 11:21 PM
I think I figured it out and, why I couldn't get it to operate. This basically plugs the fuel return line. I was using air against it and, air compresses. As a fluid pushes against it, this should flex up enough to let the fluid back into the tank but, not allow the fluid to return out to the pump through the return line. Pretty ingenious little tool if that is indeed how it works. Someone with their tank out have a look cause these bone heads think I've been torquing one up! (IMG:style_emoticons/default/biggrin.gif) I always wonder what differs the return from the delivery. |
Eric_Shea |
Mar 12 2012, 11:26 PM
Size and feature set.
The supply line is a larger opening completely through into the tank. This allows for the long screen to be placed over the end of the nozzle and into the tank. it has the larger 10mm nozzle The return is a smaller 7mm nozzle. It does not go direct into the tank as you can see here, it feeds into a smaller chamber that goes into the tank. |
Mike Bellis |
Mar 12 2012, 11:28 PM
My tank did not have it. Return usually should be free flowing and not an automatic pressure releif valve.
Eric_Shea |
Mar 12 2012, 11:34 PM
QUOTE Return usually should be free flowing and not an automatic pressure releif valve Why is that Mike? Is this a FI thing that keeps a certain amont of pressure on the line? |
Mike Bellis |
Mar 12 2012, 11:40 PM
QUOTE Return usually should be free flowing and not an automatic pressure releif valve Why is that Mike? Is this a FI thing that keeps a certain amont of pressure on the line? A rubber plug is not callibrated and can get worn and come loose. The pressure regulator (callibrated) is usually on the return line right after the fuel rail. This keeps the supply line pressurized and allows free flowing return fuel. |
SLITS |
Mar 13 2012, 09:10 AM
Ok ... of the five (5) fuel tanks I just examined, none of them have the plug you show. The have a cap with about a 3/16" hole in them for the return. No separate "tank" that they feed into.
Looks like someone used a rubber expanding freeze plug and cut the top of the bolt off for whatever reason. or they drove a piece of rod into the hole But you're building one of them pinky lifter / gold chain cars and don't need a return anyway. |
McMark |
Mar 13 2012, 09:15 AM
I bet you had the tank coated by a shop, and they left that in there from when they coated it (inside or out). (IMG:style_emoticons/default/wink.gif)
There is NOTHING but steel in the tank body. No fancy anything. Just a steel can with a couple threaded fittings on the bottom. |
Eric_Shea |
Mar 13 2012, 09:41 AM
It was in there before it was coated. I just did the POR coating. This is a 74 tank if that matters...
Eric_Shea |
Mar 13 2012, 09:42 AM
You can't really get a hand in the tank to install this. I doubt a shop put it in. That and the fact that it is the prefect diameter to fit in the return nipple. (IMG:style_emoticons/default/confused24.gif)
McMark |
Mar 13 2012, 09:47 AM
Then someone dropped it in and it got wedged there. It isn't supposed to be there and it's only going to cause you headaches down the road.
Eric_Shea |
Mar 13 2012, 09:57 AM
I hate you. (IMG:style_emoticons/default/biggrin.gif)
Aaron Cox |
Mar 13 2012, 10:01 AM
Eric, i'm sorry someone put something in your bunghole.
I'm sure this too shall pass. (IMG:style_emoticons/default/tongue.gif) |
SLITS |
Mar 13 2012, 10:07 AM
Eric, i'm sorry someone put something in your bunghole. I'm sure this too shall pass. (IMG:style_emoticons/default/tongue.gif) Who are you and why are you posting here? Eric always has something in his bunghole .. not that there is anything wrong with that. |
ChrisFoley |
Mar 13 2012, 10:29 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Then someone dropped it in and it got wedged there. It isn't supposed to be there and it's only going to cause you headaches down the road. (IMG:style_emoticons/default/agree.gif) |
jcambo7 |
Mar 13 2012, 10:34 AM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
I think I figured it out and, why I couldn't get it to operate. This basically plugs the fuel return line. I was using air against it and, air compresses. As a fluid pushes against it, this should flex up enough to let the fluid back into the tank but, not allow the fluid to return out to the pump through the return line. Pretty ingenious little tool if that is indeed how it works. Someone with their tank out have a look cause these bone heads think I've been torquing one up! (IMG:style_emoticons/default/biggrin.gif) That's a good story! |
wingnut86 |
Mar 13 2012, 10:44 AM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Agreed on the coating plugs, used in Powder Coat as well. Another reason is hole epoxy retention, but that shit is thicker than Eric's nose hairz, and it's also in the wrong damn olace for sure.
Eric - walk into the light now, boogeyman is gone (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 12:45 PM |
