Jack supports |
Jack supports |
Black914_4 |
Mar 12 2012, 08:41 PM
Member Group: Members Posts: 272 Joined: 11-January 12 From: AR Member No.: 13,994 Region Association: South East States |
I was thinking of cutting the jack holes back a little bit and filling in the rocker panels to give it a cleaner look. I kinda dont like the way they poke out of the rocker panels.
What do you guys think? |
Rand |
Mar 12 2012, 08:48 PM
I was thinking of cutting the jack holes back a little bit and filling in the rocker panels to give it a cleaner look. I kinda dont like the way they poke out of the rocker panels. What do you guys think? I'm with you. But dig carefully, and if you find rust in those jack plates (which you probably will), I vote for taking them all the way down to the long and good clean metal. Clean it up good and shave the rockers. |
Mar 12 2012, 09:35 PM
What do you guys think? I think the plastic covers for the posts work well to hide them ... (IMG:style_emoticons/default/shades.gif) |
Rand |
Mar 12 2012, 09:38 PM
Maybe you'll get lucky under there and all you'll need is plastic covers.
Rand |
Mar 12 2012, 09:41 PM
If you are lucky and it's ok under there, then yes, place the plugs. It won't be smooth, but it will be factory. I guess I was just thinking about what was underneath too. You know how this typically goes.
914werke |
Mar 12 2012, 10:32 PM
"I got blisters on me fingers" Group: Members Posts: 10,058 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I think....
If your gonna mod it, then go all the way. Cut out the support plate as well and replace with a section of flat stock to remove any area for dirt to collect and rot to take hold. I posted a poll thread a while back, about who has ever.. or how often in the last.. used the jack posts on their car to raise it. IMHO they (the jack posts) are body damage waiting to happen. |
Mar 13 2012, 12:19 AM
I posted a poll thread a while back, about who has ever.. or how often in the last.. used the jack posts on their car to raise it. IMHO they (the jack posts) are body damage waiting to happen. I use them all the time ... (IMG:style_emoticons/default/confused24.gif) |
Gint |
Mar 13 2012, 05:44 AM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
So do I.
TheCabinetmaker |
Mar 13 2012, 06:23 AM
I'm one of those who had body damage to my car when the jack point failed. The car was only five years old then. I removed both of them and filled in the hole in the valance. I've never used one since on any car, and like the clean look. Its your car, do what you want to it.
mrbubblehead |
Mar 13 2012, 07:00 AM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i use my jack posts too. what are going to do if you get a flat, out on the road?
TheCabinetmaker |
Mar 13 2012, 07:03 AM
I carry a small walmart floor jack.
pilothyer |
Mar 13 2012, 09:03 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
If and when you do use the factory jack, you should always chock the wheels on the other side front and rear.............ever wonder why so many factory jacks are severely twisted ? (probably not since we all know) Any way I think the factory jack points are very handy for getting the car up to work on it, especiall when you need to get all 4 wheels off the ground. Go up with one side, place jack stands and then up with the other, place jack stands.......simple.
Randal |
Mar 13 2012, 09:19 AM
I posted a poll thread a while back, about who has ever.. or how often in the last.. used the jack posts on their car to raise it. IMHO they (the jack posts) are body damage waiting to happen. I use them all the time ... (IMG:style_emoticons/default/confused24.gif) If you lower you car you will be happy to have them, given that most jacks won't slip under the car on the side rails when the car is slammed. |
tbox56 |
Mar 17 2012, 09:14 AM
Member Group: Members Posts: 54 Joined: 14-November 04 From: Colorado Member No.: 3,115 |
I removed mine, and I am glad i did. Found some rust bunnies in there, and it does give a nice clean look, especially when you replace the rocker panels at the same time. I chose some nice fiberglass ones, and will be painting them body color.
Mike Bellis |
Mar 17 2012, 09:22 AM
If you remove them, it may affect resale value. Most 914 buyers will think it's due to hacker body repair and hiding a rust issue. I suggest leaving it factory correct and live with it.
Cairo94507 |
Mar 18 2012, 08:00 AM
Michael Group: Members Posts: 9,750 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I have to agree with Mike. If I saw a car without the jacks posts I would be suspicious of damage. Personally, with the rocker caps on you don't really notice the posts at all.
Elliot Cannon |
Mar 18 2012, 11:51 AM
If you remove them, it may affect resale value. Most 914 buyers will think it's due to hacker body repair and hiding a rust issue. I suggest leaving it factory correct and live with it. That's a good point, however, I have never bought a used car (especially an old Porsche) with resale value in mind. Removing jack points lowers resale value about as much as installing a V8. (IMG:style_emoticons/default/happy11.gif) |
Black914_4 |
Mar 18 2012, 12:10 PM
Resale value is something I must concider. I think it would look better without them. I don't have a good track record on keeping vehicles very long though. Ussually a couple years and I'm ready for something new.
Robert21 |
Mar 18 2012, 05:15 PM
ron21 Group: Members Posts: 288 Joined: 9-July 04 From: Seal Beach Ca 90630 Orange co Member No.: 2,330 Region Association: None |
Resale value is something I must concider. I think it would look better without them. I don't have a good track record on keeping vehicles very long though. Ussually a couple years and I'm ready for something new. If your looking for resale value , you got the wrong car , I will never get the money i put in the car , but i,am having alot of fun with it the last 8 years. Attached image(s) |
Black914_4 |
Mar 18 2012, 05:37 PM
Resale value is something I must concider. I think it would look better without them. I don't have a good track record on keeping vehicles very long though. Ussually a couple years and I'm ready for something new. If your looking for resale value , you got the wrong car , I will never get the money i put in the car , but i,am having alot of fun with it the last 8 years. I am only going to have $5k-$6k in the car by the time I get done in a couple months. I plan on enjoying it and driving it for quite a while. But I want to still be able to get my money back out of it when I decide to swap for something different. |
Lo-Fi Version | Time is now: 14th May 2024 - 09:53 AM |
