| Allan |
Sep 20 2004, 02:03 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Trying to pull the flywheel and noticed that the bolts seemed to have been ground down. Would someone do this so the flywheel could be surfaced beyond minimum specs. and the clutch would still clear. Also, what are the bolts made of? Looks like brass.
| SirAndy |
Sep 20 2004, 02:07 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,562 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Headrage @ Sep 20 2004, 01:03 PM) Would someone do this so the flywheel could be surfaced beyond minimum specs. and the clutch would still clear. ayup, that's exactly what it is ... (IMG:style_emoticons/default/cool.gif) Andy |
| Brad Roberts |
Sep 20 2004, 02:31 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
The 4 spring discs hit the bolt heads after machining the flywheel down to a certain point. This is one of the reasons why we dont sell 4 spring discs anymore.
B |
| Allan |
Sep 20 2004, 02:32 PM
Great. Now the problem is getting them out. There is only about 1/4 inch to grab on to. Probably end up grinding them off. (IMG:style_emoticons/default/headbang.gif)
| Brad Roberts |
Sep 20 2004, 02:34 PM
I'm betting you will end up replacing that flywheel/disc/pp.
B |
| SLITS |
Sep 20 2004, 02:42 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
QUOTE(Headrage @ Sep 20 2004, 01:32 PM) Great. Now the problem is getting them out. There is only about 1/4 inch to grab on to. Probably end up grinding them off. (IMG:style_emoticons/default/headbang.gif) Cold steel chisel and BFH to get them turning. |
| Allan |
Sep 20 2004, 02:44 PM
QUOTE(SLITS @ Sep 20 2004, 12:42 PM) Cold steel chisel and BFH to get them turning. I'm gonna try that first and see what happens. And I will be replacing everything. |
| Allan |
Sep 20 2004, 04:12 PM
I was looking at Pelican for replacement flywheel bolts and the picture shows them as round hex bolts. Mine are regular bolts. Is it a bad pic. or a replacement?
| Allan |
Sep 20 2004, 05:06 PM
HOOORAY!! Got the bolts out and flywhell off. Problem is now that I think I have too much play in the crank. Can anyone tell me how much you should be able to slide the crank in and out. It looks to be moving about 1/8th of an inch. Too much?
| SLITS |
Sep 20 2004, 05:15 PM
End play is what you are asking about - 0.003 - 0.005" (0.07 - 0.13 mm) according to Tom Wison's Book.
| Cap'n Krusty |
Sep 20 2004, 05:27 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Gotta torque the flywheel back on , WITH the shims, in order to check the end play. The Cap'n
| Allan |
Sep 20 2004, 05:43 PM
Is end play adjusted with flywheel shims alone or are there internal adjustments (bearings, etc.)?
| Cap'n Krusty |
Sep 20 2004, 07:35 PM
Just the shims. Of course, if the bearing is moving in the case, it's a whole different thing. Pretty uncommon in T4 motors, though ............. The Cap'n
| Allan |
Sep 20 2004, 08:07 PM
I really appreciate the info. on this stuff. Being my first time at this I get nervous when delving into unfamiliar territory. You guys are great.
| SLITS |
Sep 20 2004, 09:37 PM
Cap'n - don't you torque the flywheel without shims and measure endplay with a dial indicator to determine the thickness of shims to add?
Lo-Fi Version | Time is now: 12th November 2026 - 01:21 AM |
