Intermittent windshield wipers, Upgrading or installing intermittent wipers. |
steuspeed |
Mar 14 2012, 04:50 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Anyone figure out a slick way to implement intermittent wipers?
Bleyseng |
Mar 14 2012, 04:53 PM
On 74 and later you could get "Flickwipe" or intermittent wipers. On a 73 you'll have to upgrade to a later style wiper switch with the right extra contacts.
Do a search as there is a great thread all about howtodoit...... |
Tom_T |
Mar 14 2012, 04:55 PM
Contact Jeff Bowlsby for an intermittent relay (his repro of the OEM one) or try to find a used or NOS factory one - install, then use needle nose pliers to remove the 3rd indent stopper at the top position of the column wiper switch (a perforated plastic cover).
Voila! Intermittent Wipers the same way that the factory & dealers did it! EDIT per Geoff's post - AFAIK all column switches except the 914-6 with electric pump window washers have the contacts just past the "normal" 2nd & were accessed by popping out the 3rd indent blocking piece. Check with Bolwsby - he'll know for sure! |
Mar 14 2012, 05:53 PM
Resident German Group: Admin Posts: 41,626 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Anyone figure out a slick way to implement intermittent wipers? Is using the factory harness and relay not slick enough? (IMG:style_emoticons/default/confused24.gif) |
steuspeed |
Mar 14 2012, 06:37 PM
Anyone figure out a slick way to implement intermittent wipers? Is using the factory harness and relay not slick enough? (IMG:style_emoticons/default/confused24.gif) I didn't know the 74 and up had intermittent option. Yeah, that is slick! Wish I asked about this last fall. |
orange914 |
Mar 14 2012, 06:56 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Contact Jeff Bowlsby for an intermittent relay (his repro of the OEM one) or try to find a used or NOS factory one - install, then use needle nose pliers to remove the 3rd indent stopper at the top position of the column wiper switch (a perforated plastic cover). Voila! Intermittent Wipers the same way that the factory & dealers did it! EDIT per Geoff's post - AFAIK all column switches except the 914-6 with electric pump window washers have the contacts just past the "normal" 2nd & were accessed by popping out the 3rd indent blocking piece. Check with Bolwsby - he'll know for sure! Seems to be a VW thing. I just got done upgrading my 83 rabbit pickup to "factoty" intermittant by pulling a blocking stop in the swich & changing to the right relay. Similiar to 914??? Maybe this will help |
RickS |
Mar 14 2012, 07:08 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Same deal for a 71? the question is where the relay goes.
Mar 14 2012, 07:53 PM
Same deal for a 71? the question is where the relay goes. No. Early cars don't have the wiring in the column for it. The relay goes into the socket that is part of the (optional) harness. (IMG:style_emoticons/default/idea.gif) |
Valy |
Mar 14 2012, 08:41 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
RickS |
Mar 14 2012, 10:16 PM
Same deal for a 71? the question is where the relay goes. No. Early cars don't have the wiring in the column for it. The relay goes into the socket that is part of the (optional) harness. (IMG:style_emoticons/default/idea.gif) Curses! Foiled again!! (except with option harness and newer column - which ain't happening). |
Eric_Shea |
Mar 14 2012, 10:43 PM
The relay mounts on the cowl post on the drivers side.
(IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-a.akamaihd.net-1110-1331786625.1.jpg) Thanks to Valy's help and Jeff's harness, mine is up and running with an electric pump. Very happy with the install. (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-a.akamaihd.net-1110-1331786627.2.jpg) |
swood |
Mar 15 2012, 12:15 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
I still need to figure out how to do that...i have the pump, relay and the replacement column switch. :/
Drums66 |
Mar 15 2012, 03:14 PM
The relay mounts on the cowl post on the drivers side. (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-a.akamaihd.net-1110-1331786625.1.jpg) Thanks to Valy's help and Jeff's harness, mine is up and running with an electric pump. Very happy with the install. (IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-a.akamaihd.net-1110-1331786627.2.jpg) ......Exactly Bro!!....I have a nos 1 for sale? |
Lo-Fi Version | Time is now: 11th May 2024 - 01:44 AM |
