mistake in placement of post, question for the Dr or anyone else |
worn |
Mar 15 2012, 09:30 AM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I bought a side shift transmission and of course the first thing I did was to take the back cover off. Good news is the dog teeth look sharp. OK, not really going to work on this right now, lets button it back up. No go. It appears that all or at least a few of the studs are splayed slightly outwards and I can get things lined up but the ting won't tap back together. I have reverse sliding across it's gear, and I am watching the notched thrust piece try to slide off, but it won't quite go. Any thoughts before I break something?
Dr Evil |
Mar 15 2012, 03:02 PM
If you got it off, then you should be able to get it on. Once the studs are in the holes, it is the idler gear stud (big honker poking out of the tail cone) that needs to thread through the flat bearing and the notch washer. The only other possible sticking point might be the speedo drive (take it out) before putting the cone on.
Thanks for pointing me to this thread, rmital (IMG:style_emoticons/default/wink.gif) |
Aaron Cox |
Mar 15 2012, 03:11 PM
If you got it off, then you should be able to get it on. Once the studs are in the holes, it is the idler gear stud (big honker poking out of the tail cone) that needs to thread through the flat bearing and the notch washer. The only other possible sticking point might be the speedo drive (take it out) before putting the cone on. Thanks for pointing me to this thread, rmital (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/welcome.png) Replies belong in the garage (IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/av-943.gif) |
Dr Evil |
Mar 15 2012, 03:15 PM
Who are you! (IMG:style_emoticons/default/blink.gif)
Lo-Fi Version | Time is now: 11th May 2024 - 05:50 PM |
