Gauges....Where to mount and how?, Just bought and AFR Gauge and probe. |
falconfp2001 |
Mar 15 2012, 12:35 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I'm just starting my Megasquirt Install prep and need to mount my AFR Gauge. I'll mount it first because it can run independently of the MEgasquirt.
I don't want to cut my lower pad or my upper pad as they are nearly perfect and I like to keep the look as stock as possible. Any suggestions or maybe pics of how you have added gauges would be much appreciated. I have a 1971 1.7L with stock injection. I want to mount the Gauge under the dash just a little left of the center point of the dash. Any suggestions? |
McMark |
Mar 15 2012, 01:11 PM
Some people pull out the ashtray assembly and use those mounting points. Some people remove the radio and install it there. Some people use a stock center console and replace the clock. 914Appearance and Performance sells a piece that replaces the A-pillar pad and mounts two gauges.
jsayre914 |
Mar 15 2012, 02:57 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Some people use a stock center console and replace the clock. 914Appearance and Performance sells a piece that replaces the A-pillar pad and mounts two gauges. I just did both of these ideas last weekend, replaced the clock and the pillar guages. I think it looks pretty good. Just dont tell scottyB or Dr Evil, they will poke fun at you (IMG:style_emoticons/default/poke.gif) Attached image(s) |
914_teener |
Mar 15 2012, 05:46 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Some people use a stock center console and replace the clock. 914Appearance and Performance sells a piece that replaces the A-pillar pad and mounts two gauges. I just did both of these ideas last weekend, replaced the clock and the pillar guages. I think it looks pretty good. Just dont tell scottyB or Dr Evil, they will poke fun at you (IMG:style_emoticons/default/poke.gif) There was a thread about this for the center console. Looked really good. I think it was the guy who was installing the FI setup that Mark sells. I liked the way it looked. |
Mike Bellis |
Mar 15 2012, 05:53 PM
I pulled the ashtray for my boost controller. Use the same mounting screws as the astray bracket.
falconfp2001 |
Mar 15 2012, 09:39 PM
I'm trying to stay away from the Center console. MY direction is for a future CarPC and touch screen for, Nav, Internet, Radio, Media Center, Engine Management and data logging, etc.
Underneath the center of the dash is just perfect for one of these then a 10" touch screen display. I can then tune while traveling and everything else. http://www.qualitymobilevideo.com/armr200.aspx But the O2 s3ensor and gauge are separate so I want a clean install of a single or dual gauge that won't clutter the lower center of the dash. I also would like to not cut the dash at all. That way it can still look stock with the touch screen pushed up under the dash when not in use |
GeorgeRud |
Mar 15 2012, 09:45 PM
The ashtray location works great for mounting two VDO or other 2 1/16" gauges. VDO makes a bracket out of rubber that can easily be cut to fit (simply remove the angled top section and drill two holes to utilize the stock ashtray mounting holes). The location makes it easy to see the gauges, and is reversible as no parts of the dash were cut to do the install.
Kirmizi |
Mar 15 2012, 10:27 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Here's an idea Demick posted awhile back
rwilner |
Mar 16 2012, 07:26 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Some people use a stock center console and replace the clock. 914Appearance and Performance sells a piece that replaces the A-pillar pad and mounts two gauges. I just did both of these ideas last weekend, replaced the clock and the pillar guages. I think it looks pretty good. Just dont tell scottyB or Dr Evil, they will poke fun at you (IMG:style_emoticons/default/poke.gif) There was a thread about this for the center console. Looked really good. I think it was the guy who was installing the FI setup that Mark sells. I liked the way it looked. I'm that guy! Somehow I don't have a "finished" pic but here's some pics of the install of an innovate LC-1 Sensor / Brain mtg 1: (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-11530-1331904407.1.JPG) Sensor / Brain mtg 2: (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-11530-1331904409.2.JPG) Custom center console plate: (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-11530-1331904409.3.png) Mock up complete in cardboard...AFR gauge is in the upper left: (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.googleusercontent.com-11530-1331904411.4.JPG) |
Lo-Fi Version | Time is now: 10th May 2024 - 02:58 PM |
