Holes for spot-welds, 1/4", 7/16", 3/8" |
watsonrx13 |
Sep 20 2004, 05:22 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
OK, I have new pieces to weld to the car. They are attached by spot-welds.
What is the optimum hole size to drill for the holes? Please select from 1/4", 7/16", 3/8" Suspension pieces - Body pieces - And yes, I'm using a MIG welder and will use the rossette method. |
MarkV |
Sep 20 2004, 05:39 PM
They make an air tool that punches the holes. The size of the die on the tool is 3/16".
TimT |
Sep 20 2004, 05:45 PM
Yea 3/16"
1/4"+ is to big that air punch/crimper is the shizzle. make sure you get "tight iron" ( LOL I work with ironworkers... that means "fits well") otherwise youll likely have some nasty looking welds ... lots of vise grips... and weld from the bottom up |
Lo-Fi Version | Time is now: 15th May 2024 - 10:27 AM |
