blank page engine rebuild, what would you do? |
Type 47 |
Mar 15 2012, 06:54 PM
Senior Member Group: Members Posts: 781 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
My 75' 62k mile 914 is ready to redo...the original 2.0 is going to get the FI put back on, then taken out of the car and put in storage.
I have a 73' 2.0 that I want to build and put in the re-done car: What would you do with the engine build? I'm taking off Webers from the original car...that's a starting point. |
bigkensteele |
Mar 15 2012, 07:01 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I would start by posting 2 identical threads and see which way each of them goes. (IMG:style_emoticons/default/poke.gif)
wingnut86 |
Mar 15 2012, 07:49 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Damn, that's some funny shit.
I'll just install a Suby and keep quiet when it's my turn (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/WTF.gif) |
Type 47 |
Mar 17 2012, 07:03 PM
I would start by posting 2 identical threads and see which way each of them goes. (IMG:style_emoticons/default/poke.gif) OK that's a start...I guess there are just two options? (IMG:style_emoticons/default/icon_bump.gif) |
Type 47 |
Mar 17 2012, 07:06 PM
Damn, that's some funny shit. I'll just install a Suby and keep quiet when it's my turn (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/WTF.gif) Conversions are not an option...too much (IMG:style_emoticons/default/welder.gif) chop, cut, and rebuild. We are talking about options for the 2.0. |
wndsrfr |
Mar 17 2012, 08:06 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
My 75' 62k mile 914 is ready to redo...the original 2.0 is going to get the FI put back on, then taken out of the car and put in storage. I have a 73' 2.0 that I want to build and put in the re-done car: What would you do with the engine build? I'm taking off Webers from the original car...that's a starting point. Grab the HAM heads dada is selling. Send the case & heads to len hoffman for decking & any refresh,, he will do it right. Plug the oil galleys too. Bore your oem cylinders to 96mm. Get Jakes cam & a set of pistons, KBs ok for street, JEs for track. Get the rotating assembly balanced. Set deck height to get 10: 1 CR. Put on a high volume full flow oil filter & cooler. Get Chris' s headers (tangerine). Fill with Brad Penn oil. Start it up & just try to wipe that huge grin off your face!! Priceless! |
shuie |
Mar 17 2012, 08:09 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
I'd just send it to Greg at FAT performance. I basically sent him a junk core (almost all of it turn out to be garbage) and he sourced everything for the build. After maybe a half dozen phone calls and a ~2 month wait I had a nice broken in 2258 with dyno sheet back in my garage waiting to go into the car. If I had to do this over again, the only thing I would change would be to start by sending FAT a running core with known solid rebuildable parts.
Elliot Cannon |
Mar 17 2012, 10:41 PM
I'd just send it to Greg at FAT performance. I basically sent him a junk core (almost all of it turn out to be garbage) and he sourced everything for the build. After maybe a half dozen phone calls and a ~2 month wait I had a nice broken in 2258 with dyno sheet back in my garage waiting to go into the car. If I had to do this over again, the only thing I would change would be to start by sending FAT a running core with known solid rebuildable parts. (IMG:style_emoticons/default/agree.gif) |
Type 47 |
Mar 18 2012, 12:06 PM
I'd just send it to Greg at FAT performance. I basically sent him a junk core (almost all of it turn out to be garbage) and he sourced everything for the build. After maybe a half dozen phone calls and a ~2 month wait I had a nice broken in 2258 with dyno sheet back in my garage waiting to go into the car. If I had to do this over again, the only thing I would change would be to start by sending FAT a running core with known solid rebuildable parts. Sounds like a good time frame while i'm disassembling & painting. What were the dyno #'s? What's a ball park on cost? is that a carb or FI setup? does it use an MSD ignition? Thanks |
Type 47 |
Mar 18 2012, 12:08 PM
My 75' 62k mile 914 is ready to redo...the original 2.0 is going to get the FI put back on, then taken out of the car and put in storage. I have a 73' 2.0 that I want to build and put in the re-done car: What would you do with the engine build? I'm taking off Webers from the original car...that's a starting point. Grab the HAM heads dada is selling. Send the case & heads to len hoffman for decking & any refresh,, he will do it right. Plug the oil galleys too. Bore your oem cylinders to 96mm. Get Jakes cam & a set of pistons, KBs ok for street, JEs for track. Get the rotating assembly balanced. Set deck height to get 10: 1 CR. Put on a high volume full flow oil filter & cooler. Get Chris' s headers (tangerine). Fill with Brad Penn oil. Start it up & just try to wipe that huge grin off your face!! Priceless! This sound like a good setup too...same question as above...HP, torque, carb/FI, cost? |
shuie |
Mar 18 2012, 12:36 PM
I'd just send it to Greg at FAT performance. I basically sent him a junk core (almost all of it turn out to be garbage) and he sourced everything for the build. After maybe a half dozen phone calls and a ~2 month wait I had a nice broken in 2258 with dyno sheet back in my garage waiting to go into the car. If I had to do this over again, the only thing I would change would be to start by sending FAT a running core with known solid rebuildable parts. Sounds like a good time frame while i'm disassembling & painting. What were the dyno #'s? What's a ball park on cost? is that a carb or FI setup? does it use an MSD ignition? Thanks Dyno showed 153hp and 175ft. lbs of torque @ 4500RPM, 44mm carbs, no MSD. Id guess ~$8k total cost with shipping, sourcing parts, etc... You could probably get it done cheaper. I had a lot of extra costs here because of the issues with my core. |
Type 47 |
Mar 19 2012, 07:51 PM
I'd just send it to Greg at FAT performance. I basically sent him a junk core (almost all of it turn out to be garbage) and he sourced everything for the build. After maybe a half dozen phone calls and a ~2 month wait I had a nice broken in 2258 with dyno sheet back in my garage waiting to go into the car. If I had to do this over again, the only thing I would change would be to start by sending FAT a running core with known solid rebuildable parts. Sounds like a good time frame while i'm disassembling & painting. What were the dyno #'s? What's a ball park on cost? is that a carb or FI setup? does it use an MSD ignition? Thanks Dyno showed 153hp and 175ft. lbs of torque @ 4500RPM, 44mm carbs, no MSD. Id guess ~$8k total cost with shipping, sourcing parts, etc... You could probably get it done cheaper. I had a lot of extra costs here because of the issues with my core. Wow, those #'s are incredible |
Lo-Fi Version | Time is now: 10th May 2024 - 02:31 PM |
