4 to 5 lug conversion, Narrow body, '74 |
Als914 |
Mar 15 2012, 11:00 PM
Lighting my way Group: Members Posts: 330 Joined: 1-January 06 From: Hemet,Ca. Member No.: 5,346 Region Association: Southern California |
Hello all,
With all the parts stash I collected over the years it's time to put the five lug Fuch's on my narrow body, '74 picture below. I have 6x16 front and 7x16 rear. The rears will be using a converted four lug to five lug hub w/ powder coated trailing arms and new bearings and bushings. I don't anticipate using any wheel spacers. The studs that I plan to use for the front rotors are the M14 x 1.5 x ?? screw in type. My question is, what is the length of the stud I should buy? Where can I buy them? Any help would be appreciated. |
Eric_Shea |
Mar 15 2012, 11:23 PM
Spoke |
Mar 16 2012, 06:08 AM
How do you plan to widen the rear fenders? I don't think the 7x16's will fit without pulling the fenders out a bit.
Aaron Cox |
Mar 16 2012, 08:50 AM
How do you plan to widen the rear fenders? I don't think the 7x16's will fit without pulling the fenders out a bit. Some cars fit them better than others but some tugging rolling WILL be required to get 205's on 7's back there. 205's on 6" are a better bet and still require a lip massage.... I've seen narrowed trailing arms done to fit 7's under stock fenders.. but thats a LOT of work. Do you need some PMB 4 lug to 5 lug hubs? (Just surplus'd the set that was on my car....) |
Grelber |
Mar 16 2012, 09:04 AM
Insert favorite Don Rickles joke here. Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
I went with 16 X 6's all around. Had to put spacers on the front to fill the well, but I really like the finished product. The 6's BARELY fit in the back with no pulling.
Als914 |
Mar 16 2012, 10:27 AM
How do you plan to widen the rear fenders? I don't think the 7x16's will fit without pulling the fenders out a bit. Some cars fit them better than others but some tugging rolling WILL be required to get 205's on 7's back there. 205's on 6" are a better bet and still require a lip massage.... I've seen narrowed trailing arms done to fit 7's under stock fenders.. but thats a LOT of work. Do you need some PMB 4 lug to 5 lug hubs? (Just surplus'd the set that was on my car....) Got them Aaron, Thanks |
Als914 |
Mar 16 2012, 10:28 AM
Thanks Eriic. |
a914622 |
Mar 16 2012, 01:57 PM
Member Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
Iv got my screw in style studs from 034 motorsports. The come with nuts. Iv used them on the front of the vanagon for a lexus brake swap.
jcl |
JRust |
Mar 16 2012, 03:26 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I fit 7x16 Fuchs on all 4 corners with no pulling. I do have my rear fenders rolled / shaved but they fit with 215/45/16s with no problem. The 7" up front fits great too
abnrdo |
Mar 16 2012, 03:29 PM
Member Group: Members Posts: 399 Joined: 24-September 04 From: Panama City, FL Member No.: 2,820 Region Association: South East States |
I went with 16 X 6's all around. Had to put spacers on the front to fill the well, but I really like the finished product. The 6's BARELY fit in the back with no pulling. What size tire are you runnin? Beautiful car! (IMG:style_emoticons/default/beerchug.gif) |
boogie_man |
Mar 16 2012, 03:45 PM
Member Group: Members Posts: 308 Joined: 22-April 11 From: So Cal Member No.: 12,969 Region Association: Southern California |
I went with 16 X 6's all around. Had to put spacers on the front to fill the well, but I really like the finished product. The 6's BARELY fit in the back with no pulling. What size tire are you runnin? Beautiful car! (IMG:style_emoticons/default/beerchug.gif) +1 |
TravisNeff |
Mar 16 2012, 09:02 PM
poke poke..... (IMG:style_emoticons/default/poke.gif)
So the people running 7's in the back of a narrow body car - tell us your tire size and show us some pics! I am ready for the conversion too, cant decide to go all out with 225 or 205, I might have to get some crap used tires for mockup. |
Als914 |
Mar 16 2012, 09:09 PM
JRust |
Mar 16 2012, 09:28 PM
Sorry I don't have closeups of the rear. If I still had them on my car I would get a few different angles. I unfortunately trades them off for a nice suby motor. They are on Sawtooth's beautiful green 914 in Boise now. Although I am going with 8x16 951 fuchs on my car after my flares are installed.
Attached thumbnail(s) Attached image(s) |
TravisNeff |
Mar 16 2012, 10:21 PM
Jamie, that is 215x45 rightt? Not sure if I want to go a little higher with 205x55
Grelber |
Mar 17 2012, 05:51 AM
I went with 16 X 6's all around. Had to put spacers on the front to fill the well, but I really like the finished product. The 6's BARELY fit in the back with no pulling. What size tire are you runnin? Beautiful car! (IMG:style_emoticons/default/beerchug.gif) Those are 205 x 55's all around. |
Lo-Fi Version | Time is now: 12th May 2024 - 12:20 AM |
