Center or 3rd seat belt., anyone add one? |
Ferg |
Mar 16 2012, 11:12 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I will be looking to add a center seat belt to my 73 that is on it's way. I've looked at the online pics or the oe unit ect.
I assume you use the same mounting points/bolt as the two receptacle's already in place. Anybody do this with a aftermarket or rear 911 or 944 lap belt? I have access to both. It does appear that the center receptacle may have a curved mounting tap to I assume clear the other receptacle it will share the bolt with...? Don't have the car yet to "lay" it out in person, just thinking ahead of what's involved... Ferg. |
Mar 16 2012, 12:27 PM
Resident German Group: Admin Posts: 41,631 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I will be looking to add a center seat belt to my 73 that is on it's way. I've looked at the online pics or the oe unit ect. I assume you use the same mounting points/bolt as the two receptacle's already in place. It does appear that the center receptacle may have a curved mounting tap to I assume clear the other receptacle it will share the bolt with...? Well, you should have done your homework beforehand ... (IMG:style_emoticons/default/rolleyes.gif) The center seat belts mount to a set of special threaded holes on the floorpan. Those mounting holes only exists on *early* cars! If what you ordered is a original center belt, it probably won't fit the same mounting point as the normal seatbelts. This is for early models only. (IMG:style_emoticons/default/popcorn[1].gif) |
Ferg |
Mar 16 2012, 01:20 PM
I will be looking to add a center seat belt to my 73 that is on it's way. I've looked at the online pics or the oe unit ect. I assume you use the same mounting points/bolt as the two receptacle's already in place. It does appear that the center receptacle may have a curved mounting tap to I assume clear the other receptacle it will share the bolt with...? Well, you should have done your homework beforehand ... (IMG:style_emoticons/default/rolleyes.gif) The center seat belts mount to a set of special threaded holes on the floorpan. Those mounting holes only exists on *early* cars! If what you ordered is a original center belt, it probably won't fit the same mounting point as the normal seatbelts. This is for early models only. (IMG:style_emoticons/default/popcorn[1].gif) Gotcha, my assumption was wrong... no biggie. I did not order anything yet. |
Tom_T |
Mar 16 2012, 01:36 PM
Ferg,
What we did in our 88 Westy which has the narrower rear seat than the standard Vanagon, was to add an extra belt for the middle using the same mount points with a bit longer bolt to accommodate 2 seatbelt end plats' thickness. The same should work on a 914. So unless you're trying to stay all original, I'd suggest you get a lap belt that will fit & with the angled plate or bend one to match, or use flat if not an issue. IIRC the 2+1 seating option wasn't offered after 72 MY, & only outside of the US; or it may have only been 70-71 MYs with the fixed pass. seat - I'm not sure. However, the center position seating is really tough with a center console, which is why my PO/OO had removed the Center Console before I bought my early 73 2L in 12/75, in order to seat their 2 kids for ferrying around in the 914 (3rd kid on the way was why they sold). BTW - some of the early 73 MY production bodies from Aug. or so 72 still had the extra mount point in the floor. Yours may since IIRC it's an early VIN. So I agree with Andy to wait, then see what you have & go from there. IIRC, that early 914 optional center belt was like the non-retracting rear seatbelts used in 1960's & early 70's Bugs, Ghias, Buses, 411s/412s, etc., so that may be an alternative source for used, NOS, new repro &/or reconditioned ones that would be close to or same as OE. Maybe post some pix on here as a guide to how you do it, if you do, for others to see if they want to tackle it. I may even do it if I have the extra mounts in my 8/72 built 73 2L! (IMG:style_emoticons/default/idea.gif) Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Ferg |
Mar 16 2012, 01:55 PM
Ferg, What we did in our 88 Westy which has the narrower rear seat than the standard Vanagon, was to add an extra belt for the middle using the same mount points with a bit longer bolt to accommodate 2 seatbelt end plats' thickness. The same should work on a 914. So unless you're trying to stay all original, I'd suggest you get a lap belt that will fit & with the angled plate or bend one to match, or use flat if not an issue. IIRC the 2+1 seating option wasn't offered after 72 MY, & only outside of the US; or it may have only been 70-71 MYs with the fixed pass. seat - I'm not sure. However, the center position seating is really tough with a center console, which is why my PO/OO had removed the Center Console before I bought my early 73 2L in 12/75, in order to seat their 2 kids for ferrying around in the 914 (3rd kid on the way was why they sold). BTW - some of the early 73 MY production bodies from Aug. or so 72 still had the extra mount point in the floor. Yours may since IIRC it's an early VIN. So I agree with Andy to wait, then see what you have & go from there. IIRC, that early 914 optional center belt was like the non-retracting rear seatbelts used in 1960's & early 70's Bugs, Ghias, Buses, 411s/412s, etc., so that may be an alternative source for used, NOS, new repro &/or reconditioned ones that would be close to or same as OE. Maybe post some pix on here as a guide to how you do it, if you do, for others to see if they want to tackle it. I may even do it if I have the extra mounts in my 8/72 built 73 2L! (IMG:style_emoticons/default/idea.gif) Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// Yup, when I get the car I'll look into doing just that. No center console in this car... Just want it for driving the little one's to the corner ice cream/coffee shop, like 2nd gear residential speeds. |
JeffBowlsby |
Mar 16 2012, 02:08 PM
914 Wiring Harnesses Group: Members Posts: 8,498 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I had a center aftermarket belt in my '74's awhile back. No angled plate that I remember, they just shared the same bolts as the center female receivers. Easy bolt in...and the kids love it.
Ferg |
Mar 16 2012, 02:14 PM
I had a center aftermarket belt in my '74's awhile back. No angled plate that I remember, they just shared the same bolts as the center female receivers. Easy bolt in...and the kids love it. (IMG:style_emoticons/default/smilie_pokal.gif) That's what I wanted to hear (IMG:style_emoticons/default/smile.gif) |
Tom_T |
Mar 16 2012, 02:20 PM
Yup, when I get the car I'll look into doing just that. No center console in this car... Just want it for driving the little one's to the corner ice cream/coffee shop, like 2nd gear residential speeds. The occasional "extra kid or adult" locally was what we used it for in the Westy, as it's far too tight for any distance. Kids are grown now, but I'm thinking like you for future grandkids for a short spin in my 914 - after the resto is done of course! Since I'm putting a console back into mine, they'll have to swing their legs over to the passenger side though! (IMG:style_emoticons/default/biggrin.gif) |
Tom_T |
Mar 16 2012, 02:24 PM
Ferg - try this one or look around their website:
http://www.peparts.com/Detail.bok?no=109 They're part of GoWesty in Los Osos, CA, which could be a stop off on your way to or from WCR in Monterey - if you did the PCH 1 thing up/down the cost from Morro Bay to Monterey! |
rick 918-S |
Mar 16 2012, 02:27 PM
Hey nice rack! -Celette Group: Members Posts: 20,451 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
When my kids were small I hauled four kids to the lake by crossing over the center kid and locking the seat belt from the driver side in the passanger side then crossing the passanger side over to the driver side. So the kid in the middle is double belted. (IMG:style_emoticons/default/wacko.gif) Worked for me.
Ferg |
Mar 16 2012, 02:53 PM
When my kids were small I hauled four kids to the lake by crossing over the center kid and locking the seat belt from the driver side in the passanger side then crossing the passanger side over to the driver side. So the kid in the middle is double belted. (IMG:style_emoticons/default/wacko.gif) Worked for me. (IMG:style_emoticons/default/aktion035.gif) I rode around in the back of a pickup with topper on a air mattress in the winter with a mini propane heater to keep warm. That was to go ice fishing drummond Island (IMG:style_emoticons/default/smile.gif) |
Mar 16 2012, 03:41 PM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
When my kids were small I hauled four kids to the lake by crossing over the center kid and locking the seat belt from the driver side in the passanger side then crossing the passanger side over to the driver side. So the kid in the middle is double belted. (IMG:style_emoticons/default/wacko.gif) Worked for me. (IMG:style_emoticons/default/aktion035.gif) I rode around in the back of a pickup with topper on a air mattress in the winter with a mini propane heater to keep warm. That was to go ice fishing drummond Island (IMG:style_emoticons/default/smile.gif) My friends own a spot on that island. Check my thread. The red ones are like crack. For a pic of the third seatbelt mount location. Mark |
MBowman325 |
Mar 19 2012, 11:53 AM
Member Group: Members Posts: 465 Joined: 14-July 05 From: Oklahoma City, OK Member No.: 4,413 Region Association: Southwest Region |
This is a timely thread as I was looking around at options for the third seat. I hadn't though far enough to use the exiting female anchors. I would bet that the extra 20 - 30 pounds (per side) would be minimal as far as safety concerns go in an accident.
Much longer and he'd be too big to fit. (IMG:style_emoticons/default/smile.gif) |
Tom_T |
Mar 19 2012, 12:19 PM
This is a timely thread as I was looking around at options for the third seat. I hadn't though far enough to use the exiting female anchors. I would bet that the extra 20 - 30 pounds (per side) would be minimal as far as safety concerns go in an accident. Much longer and he'd be too big to fit. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/idea.gif) .... hmmmm....back in my single days in my 914, I really didn't use female anchors on my middle seat when we sat 3 ...errr 4 abreast! (IMG:style_emoticons/default/biggrin.gif) ... So being a gentleman, I just always held the middle one in with my hand! (IMG:style_emoticons/default/happy11.gif) ... and it sure beat going ice fishin' Ferg! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 11th May 2024 - 07:05 PM |
