> identical cylinder heads?, which goes on which side?
siverson
post Sep 21 2004, 10:50 AM
Was I right? Sent from a friend via email. Car in question is a 73 2.0 w/ factory FI.
-Steve
Question:
> So pick your brain time. Putting 914 back together and I can’t figure out which cylinder head belongs on which side, or if it matters. One has the number 1 on it and the other has a 2 on it. The 2 cylinder head has an extra threaded hole between the spark plugs, but that’s about the only difference I can see. Do you remember?
My answer:
>> Hmmm, that's a tough one. The casting is the same (i.e. same part #) so either will work on either side, but there probably is a right answer to this. I guessing the extra threaded hole is probably there for the CHT (Cylinder Head Temperature) sensor. And, if I remember correctly from about EIGHT years ago (!), I think the CHT sensor is on the passenger side of the car when installed. But, honestly, that's a guess and I'd probably check with someone before you bolt everything up. Or just try, and if all the wires reach you did it right, if not, just take it all apart again. (IMG:style_emoticons/default/smile.gif)
Demick
post Sep 21 2004, 10:55 AM
Ernie made me do it!
Yes, that is right. The threaded hole is for the head temp sensor and goes on the passenger side (#3 and #4 side).
Demick
Allan
post Sep 21 2004, 10:57 AM
Teenerless Weenie
Kinda off topic but what about cylinders. Do they have some feature to tell what cylinder they are for?
DNHunt
post Sep 21 2004, 02:14 PM
914 Wizard? No way. I got too much to learn.
One of the head studs is offset. 1 and 4 can swap and 2 and 3 can swap.
Dave
- Lo-Fi Version Time is now: 7th December 2025 - 06:02 AM
