> Rear Trunk Cable Release, Pop your trunk from inside the car
Engman
post Sep 21 2004, 05:14 PM
Zoisite
This mounts the release below the E-brake handle. Everything you will need is included. A cover for the release in the trunk is also provided. Please see http://engmanparts.com for details
Engman
post Sep 24 2004, 05:00 PM
Zoisite
similar question about the shaved trunk button, ive taken out the button and filled up that center portion between the rear lights with that red transparent panel that displays Porsche, so the question is will i be able to open the trunk front within the cabin?
Yes - this is what this was designed to do. There used to be an electric solenoid kit that was made to do this. I have two of these and have not been able to make them work 100% of the time - usually wind up having to depress the trunk and hit the solenoid button many times to get this to work. I have tried using a relay with direct connection to the battery with 10G wire to no avail. Finally, I decided to develop a reliable option. All new mounting brackets and a cover to make sure that the actuator cannot be jammed from inside the rear trunk.
M
Engman   Rear Trunk Cable Release   Sep 21 2004, 05:14 PM
Engman   A look at the mechanism.   Sep 21 2004, 05:16 PM
zeetas   Hi, Do you have any of these left I am interested ...   Oct 15 2006, 11:27 PM
aylanco   Dumb question that may have already been answered:...   Sep 21 2004, 07:44 PM
Engman   This is really for the rear reflector that so many...   Sep 21 2004, 07:51 PM
MattR   Does this mean you can shave the rear trunk button...   Sep 23 2004, 09:09 PM
dlo914   similar question about the shaved trunk button, iv...   Sep 23 2004, 10:46 PM
Engman
Carlitos Way   Any pictures of this installed?   Dec 25 2004, 07:49 PM
Engman   Here are pics of it in my 73. Trunk M   Jan 3 2005, 01:37 PM
Engman   Pull handle for the release - located under the E-...   Jan 3 2005, 01:39 PM
mk114   I know this is off the subject But I am a long ti...   Mar 29 2005, 05:41 AM
jim_hoyland   Looking at your trunk picture: Is the cable enteri...   Mar 30 2005, 02:50 PM
Engman     Mar 30 2005, 05:01 PM
jim_hoyland   I like the set up; does the installation require t...   Mar 31 2005, 09:57 AM
Engman
  Mar 31 2005, 11:27 AM
Kevin Phillips   I bought this and it went in in about 25 minutes. ...   Apr 3 2005, 03:49 PM
mpjedi23   Anyone have an extra porsche reflecter they willl ...   May 11 2005, 12:41 AM
41ghost   i would like to get a couple of these you can emai...   Jun 23 2005, 11:29 AM
Engman   Just a few left..... Don't say I did'nt w...   Jun 28 2005, 02:56 PM
Engman   2 remaining.... M   Jul 3 2005, 03:03 PM
Kevin Phillips   Hi, I put in your kit but I think I have the latch...   Jul 3 2005, 07:14 PM
Engman
  Jul 3 2005, 07:49 PM
montoya 73 2.0   i have the same exact problem, but i have a questi...   Jul 7 2005, 04:02 PM
Engman   Check a couple of things... 1. Rear hood pin alig...   Jul 7 2005, 05:33 PM
montoya 73 2.0   your kit was installed in about 20 minutes. it...   Jul 7 2005, 05:37 PM
Engman   Yep it will pop up - but only a little - just enou...   Jul 7 2005, 06:59 PM
montoya 73 2.0   i guess my springs are sprung? my trunk doesn...   Jul 7 2005, 07:06 PM
Kevin Phillips   M Take the release portion off of the cable and c...   Jul 7 2005, 09:19 PM
Engman   I have been able to purchase some of the componets...   Sep 29 2005, 06:25 AM
WRX914   I have bought two items from Mark, the trunk cable...   Oct 27 2005, 11:38 AM
Engman   Cables arrived! Back in production! M   Nov 28 2005, 03:23 PM
914LUST
- Lo-Fi Version Time is now: 14th May 2024 - 09:27 PM
