Engman
Sep 21 2004, 05:14 PM
This mounts the release below the E-brake handle. Everything you will need is included. A cover for the release in the trunk is also provided. Please see
http://engmanparts.com for details
Engman
Sep 21 2004, 05:16 PM
A look at the mechanism.
aylanco
Sep 21 2004, 07:44 PM
Dumb question that may have already been answered: Will this work if your trunk is locked??
Engman
Sep 21 2004, 07:51 PM
This is really for the rear reflector that so many of us have added. It can be used with the stock trunk pushbutton lock - but the lock will not function. In other words if you lock the rear trunk it will still open by pushing the button inward, with this cable release installed. I have done this.
M
MattR
Sep 23 2004, 09:09 PM
Does this mean you can shave the rear trunk button (and still open the trunk)?
dlo914
Sep 23 2004, 10:46 PM
similar question about the shaved trunk button, ive taken out the button and filled up that center portion between the rear lights with that red transparent panel that displays Porsche, so the question is will i be able to open the trunk front within the cabin?
Engman
Sep 24 2004, 05:00 PM
Yes - this is what this was designed to do. There used to be an electric solenoid kit that was made to do this. I have two of these and have not been able to make them work 100% of the time - usually wind up having to depress the trunk and hit the solenoid button many times to get this to work. I have tried using a relay with direct connection to the battery with 10G wire to no avail. Finally, I decided to develop a reliable option. All new mounting brackets and a cover to make sure that the actuator cannot be jammed from inside the rear trunk.
M
Carlitos Way
Dec 25 2004, 07:49 PM
Any pictures of this installed?
Engman
Jan 3 2005, 01:37 PM
Here are pics of it in my 73.
Trunk
M
Engman
Jan 3 2005, 01:39 PM
Pull handle for the release - located under the E-brake
M
mk114
Mar 29 2005, 05:41 AM
I know this is off the subject But I am a long time admirer of the 914 (15 +years) but only been a owner about 1 yr I have this cream puff of a body but some one drilled holled for this reflector I was wonder where do I get one (heard 911) but if this is right what year. How do I install it . Does it require electrical? Where can I get one of those trunk releases also?
jim_hoyland
Mar 30 2005, 02:50 PM
Looking at your trunk picture: Is the cable entering the trunk directly beneath the mechanism ?
How is the cable fed to the cabin mount ?
I like your set up !
Engman
Mar 30 2005, 05:01 PM
QUOTE |
The cable follows the witing harness for the tailights thru the engine compartment, exits thru a hole below the engine lid release, and come out under the e-brake handle. You do have to drill some holes for the cable and cable mount pull. This is all in the instructions with a template for drilling the release pull mount.
Mark
jim_hoyland
Mar 31 2005, 09:57 AM
I like the set up; does the installation require the engine be removed ?
Engman
Mar 31 2005, 11:27 AM
QUOTE |
I like the set up; does the installation require the engine be removed ? |
Nope - pretty simple to install - about 45 mins or so.
I have like 10 of these left from the last run. When they are gone - they will be gone.
M
Kevin Phillips
Apr 3 2005, 03:49 PM
I bought this and it went in in about 25 minutes. Very slick!!
This guy, Sorry I can't remember your name, ROCKS!!!!
kp
mpjedi23
May 11 2005, 12:41 AM
Anyone have an extra porsche reflecter they willl part with
41ghost
Jun 23 2005, 11:29 AM
i would like to get a couple of these you can email me at Dreamzwvr@aol.com or call 1-317-431-3621 ask for Drew thanks
Engman
Jun 28 2005, 02:56 PM
Just a few left..... Don't say I did'nt warn ya....
M
Engman
Jul 3 2005, 03:03 PM
2 remaining....
M
Kevin Phillips
Jul 3 2005, 07:14 PM
Hi,
I put in your kit but I think I have the latch lined up funny. It
sticks a bit and unless my kids or wife assist with the lid it can't lift.
Any ideas on how to adjust the two latch parts.
I remember you are an engineer and have a way with things mechanical.
I, on the other hand, am just a musician.
Thanks for any advice.
kp
Engman
Jul 3 2005, 07:49 PM
QUOTE |
I put in your kit but I think I have the latch lined up funny. It sticks a bit and unless my kids or wife assist with the lid it can't lift. Any ideas on how to adjust the two latch parts. I remember you are an engineer and have a way with things mechanical. I, on the other hand, am just a musician. Thanks for any advice.
Take the release portion off of the cable and check to see that the lever moves freely between the two halves. Lossen the bolt if necessary and or pry the two halves apart some if needed. The lever was checked here for this, but perhaps it needs some minor adjustment.
The oyther possibility is your spring on the latch located on the trunk lid latch. This may be too tight. It is adjustable.
Let me know what you find.
M
montoya 73 2.0
Jul 7 2005, 04:02 PM
i have the same exact problem, but i have a question. does the trunk need to release (pop-up) a little to allow the catch to clear? my trunk doesn't do that so when i pull the release and then let it go, it re-catches. not to mention it looks like someone put some weld on the catch to build it up. should i file it down?
Engman
Jul 7 2005, 05:33 PM
Check a couple of things...
1. Rear hood pin alignment - this is adjustable.
2. The 'catch' located in the rear trunk lid is adjustable also up and down - it is screwed in and there is a nut on the back. You may have it either too loose or too tight.
It really sounds like the problem is in this area.
M
montoya 73 2.0
Jul 7 2005, 05:37 PM
your kit was installed in about 20 minutes. it's great, i love it! i recommend it highly. i agree on the problem being in that area. so is the trunk supposed to pop-up a little to allow the pin to clear? i always had to push the button and lift at the same time to open the trunk.
Engman
Jul 7 2005, 06:59 PM
Yep it will pop up - but only a little - just enough for the latch to clear the catch.
Still have 2.
M
montoya 73 2.0
Jul 7 2005, 07:06 PM
i guess my springs are sprung? my trunk doesn't do that. will have to replace. thanks again! your kit went in with no problems! my car has the problem!
Kevin Phillips
Jul 7 2005, 09:19 PM
M[/QUOTE]
[/QUOTE]Take the release portion off of the cable and check to see that the lever moves freely between the two halves. Lossen the bolt if necessary and or pry the two halves apart some if needed. The lever was checked here for this, but perhaps it needs some minor adjustment.
The mechanism works great. It is binding up because the top is not lined up. If I take it off the lidd and press it in it will fly when I pull the magic nob. I have something out of line.
kp
Engman
Sep 29 2005, 06:25 AM
I have been able to purchase some of the componets in smaller lot sizes, sooooo these will be back in 4-6 weeks.
I do have 1 left currently.
M
WRX914
Oct 27 2005, 11:38 AM
I have bought two items from Mark, the trunk cable release, and the third stop light. Both items are what the doctor ordered! Mark is a honest man, he delivers exactly what he advertises... Great products Mark!
You da Man!
Keith
Engman
Nov 28 2005, 03:23 PM
Cables arrived!
Back in production!
M
914LUST
Aug 26 2006, 07:19 PM
QUOTE(Engman @ Nov 28 2005, 02:23 PM)
Cables arrived!
Back in production!
M
Hi -
Do you have any stock? My solenoid just died and untimely death... if yes, how much and lead time?
Thanks,
Rich
Engman
Sep 1 2006, 11:07 AM
PM sent
I have these in stock. As well as all of my other stuff as well.
M
zeetas
Oct 15 2006, 11:27 PM
Hi,
Do you have any of these left I am interested in buying one.
Thanks
Engman
Oct 16 2006, 07:00 AM
Yes - PM or email me.
Thanks
Mark
iamchappy
Nov 9 2006, 09:35 PM
One please, PM'ed
Chap
FB914
Nov 10 2006, 11:05 PM
QUOTE(iamchappy @ Nov 9 2006, 07:35 PM)
One please, PM'ed
Chap
If you still have one left, I'd like to buy it. Thanks
Frank B
Engman
Nov 12 2006, 02:38 PM
PM's sent.
I have several of these currently in stock.
stepuptotheMike
May 8 2010, 08:45 AM
Are these still available?
Mike
my928s4
May 12 2010, 08:55 AM
Finally got around to needing this and now I cannot see it on the Engman website.
biosurfer1
May 17 2010, 11:56 AM
I'd be very interested if you had another run also...just got a reflector in great condition ready to go in!
eric914
May 27 2010, 07:31 PM
Add me to the "are these still available" list.
tat2dphreak
May 27 2010, 08:39 PM
I installed one of these not long ago that had been sitting on the shelf... great stuff!
only thing I'd say was incorrect with the instructions were the drill sizes were too small to feed the cable through, I had to stepp up 1-2 sizes. but that might have been a slightly different cable... once installed it worked great though...
mharmon
May 28 2010, 10:56 AM
I'd take one of these as well.
Nürburg Nomad
May 28 2010, 03:33 PM
I would also like to buy one, ASAP!
Let us know if it's possible to manufacture another batch with a certain # of committed buyers???
dem
May 31 2010, 04:40 PM
I'd be interested too, if we need to make a waiting list.
Engman
Jun 1 2010, 08:41 PM
Sorry for the delay - been out of touch - lost a good friend this last week - probably the best machinist I have known - sudden heart attack - and he was healthy too, kinda hit me hard.
As to the cable release - I am looking for a replacement cable comparable in quality to what I had. So far I have bought 3 differnt ones only to find the wire without enough pull, solid wire and of course the wrong cable ends. I am continuing to look. Should I find one I will post it on the board. My goal was always to supply well built and long lasting componets, and the cables thus far have not met my standards.
Thanks
Mark
Nürburg Nomad
Jun 4 2010, 11:53 AM
Hey Mark,
Thanks for getting back to us and sorry to hear about your loss, I know it's never easy when friends pass away unexpectedly; hopefully his machine work will live on in all the vintage cars his parts are no doubt a part of...
I know you'll keep us updated so whenever you get around to it is fine, just FYI I'll probably buy a front trunk air block off kit at the same time as well, but I'm sure you keep those in stock.
914LUST
Jan 20 2011, 06:05 PM
Mark,
I hope you find a viable cable soon - my solenoid failed and I really want to replace with a manual solution.
Richard
Harpo
Sep 19 2011, 06:13 PM
Please add me to the waiting list once you find adequate components.
Thanks
David
QUOTE(dem @ May 31 2010, 02:40 PM)
