> Rear Trunk Cable Release, Pop your trunk from inside the car
Engman
post Sep 21 2004, 05:14 PM
Zoisite
This mounts the release below the E-brake handle. Everything you will need is included. A cover for the release in the trunk is also provided. Please see http://engmanparts.com for details
Kevin Phillips
post Jul 7 2005, 09:19 PM
M[/QUOTE]
[/QUOTE]Take the release portion off of the cable and check to see that the lever moves freely between the two halves. Lossen the bolt if necessary and or pry the two halves apart some if needed. The lever was checked here for this, but perhaps it needs some minor adjustment.
The oyther possibility is your spring on the latch located on the trunk lid latch. This may be too tight. It is adjustable.
The mechanism works great. It is binding up because the top is not lined up. If I take it off the lidd and press it in it will fly when I pull the magic nob. I have something out of line.
kp
Engman   Rear Trunk Cable Release   Sep 21 2004, 05:14 PM
Engman   A look at the mechanism.   Sep 21 2004, 05:16 PM
zeetas   Hi, Do you have any of these left I am interested ...   Oct 15 2006, 11:27 PM
aylanco   Dumb question that may have already been answered:...   Sep 21 2004, 07:44 PM
Engman   This is really for the rear reflector that so many...   Sep 21 2004, 07:51 PM
MattR   Does this mean you can shave the rear trunk button...   Sep 23 2004, 09:09 PM
dlo914   similar question about the shaved trunk button, iv...   Sep 23 2004, 10:46 PM
Engman
  Sep 24 2004, 05:00 PM
Carlitos Way   Any pictures of this installed?   Dec 25 2004, 07:49 PM
Engman   Here are pics of it in my 73. Trunk M   Jan 3 2005, 01:37 PM
Engman   Pull handle for the release - located under the E-...   Jan 3 2005, 01:39 PM
mk114   I know this is off the subject But I am a long ti...   Mar 29 2005, 05:41 AM
jim_hoyland   Looking at your trunk picture: Is the cable enteri...   Mar 30 2005, 02:50 PM
Engman     Mar 30 2005, 05:01 PM
jim_hoyland   I like the set up; does the installation require t...   Mar 31 2005, 09:57 AM
Engman
  Mar 31 2005, 11:27 AM
Kevin Phillips   I bought this and it went in in about 25 minutes. ...   Apr 3 2005, 03:49 PM
mpjedi23   Anyone have an extra porsche reflecter they willl ...   May 11 2005, 12:41 AM
41ghost   i would like to get a couple of these you can emai...   Jun 23 2005, 11:29 AM
Engman   Just a few left..... Don't say I did'nt w...   Jun 28 2005, 02:56 PM
Engman   2 remaining.... M   Jul 3 2005, 03:03 PM
Kevin Phillips   Hi, I put in your kit but I think I have the latch...   Jul 3 2005, 07:14 PM
Engman
  Jul 3 2005, 07:49 PM
montoya 73 2.0   i have the same exact problem, but i have a questi...   Jul 7 2005, 04:02 PM
Engman   Check a couple of things... 1. Rear hood pin alig...   Jul 7 2005, 05:33 PM
montoya 73 2.0   your kit was installed in about 20 minutes. it...   Jul 7 2005, 05:37 PM
Engman   Yep it will pop up - but only a little - just enou...   Jul 7 2005, 06:59 PM
montoya 73 2.0   i guess my springs are sprung? my trunk doesn...   Jul 7 2005, 07:06 PM
Kevin Phillips   M Take the release portion off of the cable and c...   Jul 7 2005, 09:19 PM
Engman   I have been able to purchase some of the componets...   Sep 29 2005, 06:25 AM
WRX914   I have bought two items from Mark, the trunk cable...   Oct 27 2005, 11:38 AM
Engman   Cables arrived! Back in production! M   Nov 28 2005, 03:23 PM
914LUST
- Lo-Fi Version Time is now: 15th May 2024 - 12:39 AM
