Trailing arm shims |
timothy_nd28 |
Mar 17 2012, 01:26 PM
I have aquired a 914 shell from a great 914 world member last summer. After piecing this car back together, I have runned into a potential problem in regards of putting the rear trailing arm shims back in.
On the driver side, I have the Brad Mayeur chassis kit installed along the long. However, nothing on the passenger side. Since the added thickness of this chassis kit on the driver side, which I believe to be around 1/8" thickness, do I add shims on the driver side. What about the passenger side, would I double up on shims? (being that there isnt' a chassis stiffener on that side). I'm confused on how many to put where, as this chassis kit only adds another variable to this whole mess. (IMG:style_emoticons/default/confused24.gif) |
wingnut86 |
Mar 17 2012, 02:30 PM
...boola la boo boola boo... Group: Members Posts: 1,053 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
PM Brad.
He's here on TheWorld... |
dlee6204 |
Mar 17 2012, 03:02 PM
Why isn't the kit installed on both sides?
timothy_nd28 |
Mar 17 2012, 03:07 PM
Not sure, maybe the po couldn't afford both left and right sides?
ejm |
Mar 17 2012, 03:47 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The purpose of the shim is to set the camber and an alignment is the only correct way to determine the thickness.
Lo-Fi Version | Time is now: 11th May 2024 - 06:56 AM |
