Noisy facet pump, no hijack |
jr91472 |
Sep 22 2004, 12:53 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
Didn't want to hijack the previous thread, but you guys were reading my mind. (IMG:style_emoticons/default/smile.gif) My facet pump is driving me crazy with noise (IMG:style_emoticons/default/wacko.gif) . It is mounted on the firewall.
What solution is there for this issue? Replace with a new one? If so, which? I have also been considering fabricating some kind of thick rubber mount to help dampen. Anyone have any ideas? Btw: 914-4 1.7L |
MattR |
Sep 22 2004, 01:01 PM
The rotary pump from CB Performance is supposed to be quiet and should be a direct install for carb applications. I think its ~$55 from CB.
theol00 |
Sep 22 2004, 01:06 PM
Member Group: Benefactors Posts: 242 Joined: 22-January 04 From: Campbell, CA Member No.: 1,586 |
try rubber mounts - they helped to quite mine down
lapuwali |
Sep 22 2004, 01:11 PM
Rubber mounts help a great deal. If it's solid mounted, the entire panel it's attached to is turned into a big speaker. Personally, I like some noise from the pump, so I know it's running.
Cap'n Krusty |
Sep 22 2004, 01:39 PM
I have a Pierberg ratary pump on my 911 and it has been sufficient for the webers, quiet, and relaible. I sell a lot of them here at the shop. I don't like Facet electronic "pulse" pumps because of the noise, the inadequate flow, and the need for a regulator. The Cap'n
DonTraver |
Sep 22 2004, 02:02 PM
Senior Member Group: Members Posts: 829 Joined: 5-August 04 Member No.: 2,461 |
The rotary pump sounds interesting, do you have specs, psi, gallons per hour, cost? I might be interested. Thanks
J P Stein |
Sep 22 2004, 02:21 PM
Damn.......here I thought I was OK after running the Facet for
track days & God knows what else....without a pressure reg. too....for all this time. Now I come to find out it ain't worth spit....besides being noisy. I feel so....inadequate (IMG:style_emoticons/default/sad.gif) |
MattR |
Sep 22 2004, 02:37 PM
CB offers a rotary pump that delivers 3.5 psi and 5.5 psi. Both deliver 30 gph and are priced at 53 dollars and come with a fuel filter. I have one sitting in a box. Its going in my 914 as soon as the engine is finished up.
rhodyguy |
Sep 22 2004, 04:07 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
shhh, i can't hear the cb while you're typing. night and day as compared to the facet. the way i understand it though, is the rotary should be mounted low and as close to the engine as possible. i mounted mine on the lower fire wall at about the same height as the stock unit.
kevin |
DonTraver |
Sep 22 2004, 05:10 PM
The rubber mounts that the fuel pump is mounted on are part #
901-501-864-00. These are all very generic rubber mounts, I've seen them used to isolate vibration for all kinds of equipment. I know Caterpillar uses a lot of them on their G3600 engine series, most of the engine sensors were mounted on them. I like big iron, 3600's weight anywhere from 20 to 60 tons, depends how many cyclinders you want, 6 to 18, think they may be making a 20 cyclinder now. OK back OT, the rubber mounts are round approx 1 inch dia, 3/4 to 1 inch deep, with non connected studs extending from each side, most common stud size is 1/4-20 about 3/ 4 inch long. Hope this helps, I'm gonna run the Facet pump for awhile, see if I like it, may convert to the rotary pump. How ever ytou look at it, it's still cheaper that the $370 I was quoted for a stock pump. Later |
jr91472 |
Sep 22 2004, 06:22 PM
Thanks everybody. Sounds like rotory wins. (IMG:style_emoticons/default/pray.gif)
Lo-Fi Version | Time is now: 14th May 2024 - 12:40 AM |
