BUILD-OFF CHALLENGE: A New Beginning, Enter the "Ice Queen" She is getting some color!!! |
hot_shoe914 |
Mar 18 2012, 11:25 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
VaccaRabite |
Apr 8 2012, 09:09 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
With all the welding, make sure you check for squareness before you start putting stuff back on the car. You may need to bend it a touch to get door gaps right again.
Before you put the firewall in, take measurements and see if the tub warped at all. if it did its a LOT easier to fix now then it will be to fix when everything is back on. Learn from my mistakes... ;-) Zach |
hot_shoe914 |
Apr 8 2012, 11:12 AM
With all the welding, make sure you check for squareness before you start putting stuff back on the car. You may need to bend it a touch to get door gaps right again. Before you put the firewall in, take measurements and see if the tub warped at all. if it did its a LOT easier to fix now then it will be to fix when everything is back on. Learn from my mistakes... ;-) Zach I sure hope it hasn't warped but I will check it. Where should I do the measuring at? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 07:40 PM |
