Best Practices of Gas Tank restoration, Little Rust in the bottom |
Aaron Cox |
Mar 19 2012, 11:52 AM
Newb question (IMG:style_emoticons/default/av-943.gif)
Whats the best practices of gas tank resto? Pulled the tank, and the bottom has plenty of rust, but not really flaking. Ideas? You experiences? Heard muriatic(Sp?) acid + a bit of water for a few days does wonders.... |
Elliot Cannon |
Mar 19 2012, 12:39 PM
I took mine to a radiator shop and had it "boiled out" (whatever that means). There are products that you can use to then seal the tank. Hey? I thought you knew all this $hit? (IMG:style_emoticons/default/confused24.gif) Didn't you used to own one of these cars? (IMG:style_emoticons/default/av-943.gif)
Aaron Cox |
Mar 19 2012, 12:43 PM
I took mine to a radiator shop and had it "boiled out" (whatever that means). There are products that you can use to then seal the tank. Hey? I thought you knew all this $hit? (IMG:style_emoticons/default/confused24.gif) Didn't you used to own one of these cars? (IMG:style_emoticons/default/av-943.gif) Yuuuup.... never had to mess with the tank last 'build'. Idea's on cost elliot? |
Bob L. |
Mar 19 2012, 12:51 PM
Senior Member Group: Members Posts: 847 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
I took mine to a radiator shop and had it "boiled out" (whatever that means). There are products that you can use to then seal the tank. Hey? I thought you knew all this $hit? (IMG:style_emoticons/default/confused24.gif) Didn't you used to own one of these cars? (IMG:style_emoticons/default/av-943.gif) Yuuuup.... never had to mess with the tank last 'build'. Idea's on cost elliot? I brought mine to a local Rad. shop to be boiled out and coated on the inside. All for $200. Seems like a good deal to me, after looking at the time and PITA it is to do yourself. |
poorsche914 |
Mar 19 2012, 12:53 PM
T4 Supercharged Group: Members Posts: 3,089 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
A radiator shop here in east TN quoted me $135 to clean and treat. So looks like there is quite a range as far as pricing.
(IMG:style_emoticons/default/driving.gif) |
TravisNeff |
Mar 19 2012, 12:54 PM
clean it out through electrolysis, there are a couple of threads on how to do it here. fill up your tank with water, add in about 1 cup of washing soda - take a battery charger, ground to the tank & insert some rebar in the filler hole (insulated from tank) and attach your hot lead to it. I did this on a 10 amp charge and it took me several days until it was all cleaned out.
get the caswell 2 part epoxy tank seal kit I called a radiator shop and they said it would be around 200 for a cleanout and seal. the way I did it above was $63 |
rtalich |
Mar 19 2012, 12:59 PM
Member Group: Members Posts: 279 Joined: 25-September 06 From: Bellevue, WA Member No.: 6,913 Region Association: None |
The kit from POR-15 does an amazing job!
porschefile2010 |
Mar 19 2012, 01:01 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
I agree with the POR 15. Very effective and easy to do provided you prep it all properly. If you don't set up right you can make a hell of a mess. Great result though
TravisNeff |
Mar 19 2012, 01:03 PM
Lo-Fi Version | Time is now: 9th May 2024 - 11:36 PM |
