Los Angeles: RENEGADE 1974 PORSCHE 914 V8 (Lancaster, ca) $20000 |
914World |
Mar 19 2012, 03:34 PM
Member #1 Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None |
The original vehicle was purchased at the Pomona Swap meet, and taken to Renegade Hybrids a few years later to begin the journey of restoration. This is a street driver and set up with the comforts for the street (A/C, Renegade Custom Sport Seats, upgraded Bilstein shocks, and killer stereo). If you like to cruise, look good and sounding mean doing it, this is the car for you! She is a looker!! Over $75K invested.
Restorations/Upgrades: RENEGADE HYBRIDS CONVERSION: Chevy 350-300 HP engine (cam, .030 over), Edelbrock Performer TBI Injection, A/C, 4-speed 901 Gearbox (rebuilt, regeared with taller gears, upgraded 9" clutch pkg.), Hi-Torque started, custom radiator with air deflector, hi-pressure fuel pump, bus axle adapters, Edelbrock dual headers (wrapped), SuperTrapp mufflers (smog ready but not needed 1974 exempt, in CA), 89 Carrera front suspension/Bilstein shocks front with Turbo tie-rods/rear 200# springs/ Bilstein shocks, Weltmeister adjustable sway bar kit, Bump steer kit, 19mm master cylinder/stainless steel brake lines, carbon fiber brake pads, front ventilated cross drilled rotors, rear 914 restudded cross drilled rotors, 17x8/17x10.5 Hart Odessey racing wheels (chrome/polished/gold studs/Porsche caps), 215x40ZR/275x35ZR Yokohama AVS Int., control arm stiffeners, chassis stiffener kit, front wheel bearings replaced, polygraphite rear bushings, throttle/clutch/speedometer cables replaced, rebuilt pedal cluster bushings, short shift kit/new linkage bushings, new battery/battery tray. BODY WORK BY BEACH BOYS OF VENICE BEACH: Black acrylic lacquer/clear coated, Sheridan Motorsports GT2 Widebody fiberglass rear side panels reinforced with steel, re-designed front wheel panels, C2 side rocker panels, custom designed air ports, custom front air dam, rear lite kit/electric trunk release, European light lens F/R, 911 side markers (relocated), 911 R/L side mirrors with Porsche crest bras, new windshield, new wiper assemblies, new front bumper bead, new roll bar vinyl covers, NO RUST! SAFETY CHCK AND MAINTENANCE SERVICE BY DREAM CARS OF HESPERIA: Synetic transmission gear oil, 20/50 Valvoline racing formulas motor oil, new ignition wires, spark plugs, transmission gasket, transmission sliding gear, alignment, safety wire header bolts, radiator coolant, install cut-off switch (center console), installed stainless steel fuel line, installed stainless steel radiator lines/guarded with expanded metal, install 914 VDO aluminum gauge cluster. MISCELLANEOUS REPLACEMENTS/UPGRADES: 914 VDO aluminum gauge cluster, Momo steering wheel/shifter, custom stereo/6 disc changer/power antenna/2-8" woofers, door panels, door knobs, new fog light lens, Hella halogen headlamps, European 911 horns, body seal kit, Renegade custom embroidered Sport Seats, Schroth 4-point racing harness kit, custom embroidered 914 floor mats, new pedal pads, new carpet kit, new door latches, new "Porsche" emblems/USA and Stuttgart. 377 CUBIC INCH FUEL INJECTED CHEVY 4 SPEED 4 WHEEL DISC BRAKES 17 INCH MODULAR WHEELS ALL 911 SUSPENSION AND BRAKES FACTORY A/C 2500 WATT STEREO AUTOMETER GAUGES BUILT BY RENEGADE MOTORSPORTS 65K TO BUILD BUY IT FOR $20000.00 CALL HAROLD 661 945 3749 (TIL 7 P.M.)
View the full article THIS IS NOT A 914WORLD AD! Do not reply to this thread! No one is listening! Click on the "View the full article" link above to go to the actual Ad! |
Lo-Fi Version | Time is now: 18th May 2024 - 07:41 PM |
