Restorations/Upgrades:
RENEGADE HYBRIDS CONVERSION: Chevy 350-300 HP engine (cam, .030 over), Edelbrock Performer TBI Injection, A/C, 4-speed 901 Gearbox (rebuilt, regeared with taller gears, upgraded 9" clutch pkg.), Hi-Torque started, custom radiator with air deflector, hi-pressure fuel pump, bus axle adapters, Edelbrock dual headers (wrapped), SuperTrapp mufflers (smog ready but not needed 1974 exempt, in CA), 89 Carrera front suspension/Bilstein shocks front with Turbo tie-rods/rear 200# springs/ Bilstein shocks, Weltmeister adjustable sway bar kit, Bump steer kit, 19mm master cylinder/stainless steel brake lines, carbon fiber brake pads, front ventilated cross drilled rotors, rear 914 restudded cross drilled rotors, 17x8/17x10.5 Hart Odessey racing wheels (chrome/polished/gold studs/Porsche caps), 215x40ZR/275x35ZR Yokohama AVS Int., control arm stiffeners, chassis stiffener kit, front wheel bearings replaced, polygraphite rear bushings, throttle/clutch/speedometer cables replaced, rebuilt pedal cluster bushings, short shift kit/new linkage bushings, new battery/battery tray.
BODY WORK BY BEACH BOYS OF VENICE BEACH: Black acrylic lacquer/clear coated, Sheridan Motorsports GT2 Widebody fiberglass rear side panels reinforced with steel, re-designed front wheel panels, C2 side rocker panels, custom designed air ports, custom front air dam, rear lite kit/electric trunk release, European light lens F/R, 911 side markers (relocated), 911 R/L side mirrors with Porsche crest bras, new windshield, new wiper assemblies, new front bumper bead, new roll bar vinyl covers, NO RUST!
SAFETY CHCK AND MAINTENANCE SERVICE BY DREAM CARS OF HESPERIA: Synetic transmission gear oil, 20/50 Valvoline racing formulas motor oil, new ignition wires, spark plugs, transmission gasket, transmission sliding gear, alignment, safety wire header bolts, radiator coolant, install cut-off switch (center console), installed stainless steel fuel line, installed stainless steel radiator lines/guarded with expanded metal, install 914 VDO aluminum gauge cluster.
MISCELLANEOUS REPLACEMENTS/UPGRADES: 914 VDO aluminum gauge cluster, Momo steering wheel/shifter, custom stereo/6 disc changer/power antenna/2-8" woofers, door panels, door knobs, new fog light lens, Hella halogen headlamps, European 911 horns, body seal kit, Renegade custom embroidered Sport Seats, Schroth 4-point racing harness kit, custom embroidered 914 floor mats, new pedal pads, new carpet kit, new door latches, new "Porsche" emblems/USA and Stuttgart.
377 CUBIC INCH FUEL INJECTED CHEVY
4 SPEED
4 WHEEL DISC BRAKES
17 INCH MODULAR WHEELS
ALL 911 SUSPENSION AND BRAKES
FACTORY A/C
2500 WATT STEREO
AUTOMETER GAUGES
BUILT BY RENEGADE MOTORSPORTS
65K TO BUILD BUY IT FOR $20000.00
CALL HAROLD 661 945 3749 (TIL 7 P.M.)
- it's NOT ok to contact this poster with services or other commercial interests
View the full article
THIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
