Temperature guage on instrument panel, What does it hook up to? |
ww914 |
Mar 20 2012, 06:13 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
I must be missing it, but I can't find it on the Haynes schematic.
rwilner |
Mar 20 2012, 06:33 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
ww914 |
Mar 20 2012, 06:40 PM
Thanks Rich, I got that, but I can't figure out which wire on the harness to get it to the indicator? Shoulda' marked the wires before I took it all apart.
falconfp2001 |
Mar 20 2012, 07:04 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
According to the Pelican Schematic, it should be a green with black stripe.
rwilner |
Mar 20 2012, 07:37 PM
do you have a multimeter or some way to check continuity?
If you look at where the wire bundle is routed through the engine tin under the battery, there is a single wire that breaks out of the bundle right there. This is the oil temp sender connection. You can check continuity from that spade terminal to the wires in your harness and find it that way. |
rwilner |
Mar 20 2012, 07:39 PM
do you have a multimeter or some way to check continuity? If you look at where the wire bundle is routed through the engine tin under the battery, there is a single wire that breaks out of the bundle right there. This is the oil temp sender connection. You can check continuity from that spade terminal to the wires in your harness and find it that way. here's the connector I'm talking about (IMG:http://www.914world.com/bbs2/uploads_offsite/lh3.googleusercontent.com-11530-1332293997.1.JPG) |
Valy |
Mar 20 2012, 07:43 PM
Senior Member Group: Members Posts: 1,673 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Inside the cabin, the wire usually ends near the shifter, under the carpet. It was intended to go behind the central console.
Dig a bit under the carpet and you will find the connector. |
904svo |
Mar 20 2012, 07:46 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
If you check the wiring diagram the green/black wire runs from the engine compartment to a connector located in the floor (5 connectors) for the console
it, does not go up to the dash gauge cluster. |
ww914 |
Mar 20 2012, 07:51 PM
You guys are the best. Thanks for responding. I will check this out in the morning.
Lo-Fi Version | Time is now: 11th May 2024 - 10:00 PM |
