How many CCA do we need? |
keske968 |
Mar 21 2012, 06:42 PM
Member Group: Members Posts: 132 Joined: 5-September 06 From: Papillion, Ne Member No.: 6,778 Region Association: None |
Just wondering how many CCAs a battery would need for our cars. I realize that the bigger the displacement the more CCAs we would need. I am running a 2.5 4cly that my Dad and I built up. Would 600 do it or would I need more like 800l?
gothspeed |
Mar 21 2012, 07:05 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
some factors to consider would be the state of engine tune and compression. If the car starts right up you could go lower on the CCA range. Also a hi-torque starter would demand a tad fewer amps.
Valy |
Mar 21 2012, 07:09 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
600 is an overkill already.
mskala |
Mar 21 2012, 07:57 PM
I've been using the tiny Odyssey 680 for several years, it has only 220 CCA.
While I don't drive in the winter, my car is a -6 and uses 20W-50 oil which is thick in the mornings when temp's in the 30's. Unless you're buying lawn tractor batteries you'll have plenty of amps. |
keske968 |
Mar 22 2012, 07:33 AM
Thank you all. I was planning an using a SVR 28-12 battery. It has 600 CCA, 6.88" long, 6.5" wide and 4.88" tall and cost about $140. I used two of these in my old 944 to power the car and the audio system that I had. I was hoping that it would work in the 914. Thanks all.
Lo-Fi Version | Time is now: 9th June 2024 - 05:03 PM |
