keske968
Mar 21 2012, 06:42 PM
Just wondering how many CCAs a battery would need for our cars. I realize that the bigger the displacement the more CCAs we would need. I am running a 2.5 4cly that my Dad and I built up. Would 600 do it or would I need more like 800l?
gothspeed
Mar 21 2012, 07:05 PM
some factors to consider would be the state of engine tune and compression. If the car starts right up you could go lower on the CCA range. Also a hi-torque starter would demand a tad fewer amps.
Valy
Mar 21 2012, 07:09 PM
600 is an overkill already.
mskala
Mar 21 2012, 07:57 PM
I've been using the tiny Odyssey 680 for several years, it has only 220 CCA.
While I don't drive in the winter, my car is a -6 and uses 20W-50 oil which is
thick in the mornings when temp's in the 30's.
Unless you're buying lawn tractor batteries you'll have plenty of amps.
keske968
Mar 22 2012, 07:33 AM
Thank you all. I was planning an using a SVR 28-12 battery. It has 600 CCA, 6.88" long, 6.5" wide and 4.88" tall and cost about $140. I used two of these in my old 944 to power the car and the audio system that I had. I was hoping that it would work in the 914. Thanks all.
