First and reverse grinding. |
5dogs |
Sep 24 2004, 02:02 PM
Newbie Group: Members Posts: 15 Joined: 18-September 04 From: Eureka, CA Member No.: 2,784 |
Hello, I have a tranny question. I just got the 914 on the road and it was initially shifting well. Now after a couple of days of short drives, first and reverse are almost impossible to get into without severe grinding. Could this be a clutch adjustment problem or shift linkage (or both)?? It doesn't seem it would be a synchro problem because it was shifting well at first and the fact that it is first and reverse. What is the proper procedure for adjusting clutch cable? Haynes is kind of vague. Please help!! Thanks
Red-Beard |
Sep 24 2004, 02:10 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
if 1st and reverse, then you're dragging the clutch.
rhodyguy |
Sep 24 2004, 04:02 PM
double nuts on the clutch cable?
kevin |
TBrads914/6 |
Sep 24 2004, 04:37 PM
Newbie Group: Members Posts: 16 Joined: 22-April 04 From: Lexington, KY Member No.: 1,963 |
Could be that you clutch tube has broken loose in the tunnel or where it exits the fire wall. Mine did the same thing and after re-welding in both locations it is as good as new. Be very careful at the fire wall. Your right next to the fuel lines. My car was tore apart and the lines removed. Other will have to chime in on the best safety option with the engine in the body.
Lo-Fi Version | Time is now: 14th May 2024 - 09:18 PM |
