Can I split 1/2 of the front Sway Bar Bushing?, Weltmeister hard plastic bushing |
seanery |
Sep 25 2004, 02:03 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I've got the new weltmeister plastic bushings to go onto the front bar I'm installing. There is no effin' way they will go over the square ends of the bar. Can I split 1/2 of it so it will slide over the bar? I mean, I know I can, but is it ok to do it?
Thanks (IMG:style_emoticons/default/biggrin.gif) |
DrifterJay |
Sep 25 2004, 02:14 PM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
thats how you do it....but I hear KY Silky works pretty good too though
seanery |
Sep 25 2004, 02:16 PM
I though maybe the KY warming gel could help (IMG:style_emoticons/default/w00t.gif)
jim912928 |
Sep 25 2004, 02:54 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Sean,
I just put those in mine. I talked to Brad Mayuer (sorry brad, couldn't remember how to spell your last name if I bungled it) and he said you split them just like the rear mount bushings. Put some slick grease on the inside just like the rears and you are good to go. I just slit mine with my utility blad and had them on and in within 5 minutes. The other way..forget it! Jim |
Lo-Fi Version | Time is now: 28th May 2024 - 11:51 PM |
