Okay, I got one of the heads off, Not a pretty sight |
Allan |
Sep 25 2004, 02:19 PM
Pulled the passenger side head off a little while ago. Looks like there was a good amount of blowby plus a leaky head gasket. Any comments are appreciated.
Allan |
Another
Allan |
Sep 25 2004, 02:20 PM
The head
Allan |
Sep 25 2004, 02:24 PM
Oh by the way. I can't get all of the cam followers out. Any tricks?
Eric Taylor |
Sep 25 2004, 02:33 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
Split the case (IMG:style_emoticons/default/smile.gif)
Allan |
Sep 25 2004, 02:41 PM
Well unfortunately it looks like that is exactly what I am going to have to do. Looking down into the case at the cam it looks like the cam lobes are worn out. There are spots that look like some type of plating material has worn through. (IMG:style_emoticons/default/headbang.gif)
SpecialK |
Sep 25 2004, 02:56 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Magnet? (follower removal)
Allan |
Sep 25 2004, 03:12 PM
Wont come out with a magnet. Comes up flush with the case then hits a lip or something. I don't think it really matters now being that I have to split the cases.
Sep 25 2004, 03:30 PM
looks just like any high mileage VW/Porsche 4 cylinder motor...
Split and check all the tolerances....it needs to be rebuilt... I would suggest you send the case and crank to the same place (together) to get them to check both and provide you with the proper bearings for the re-machined case and crank. The rest you should get some new stuff... new cam new P/C's blah blah blah Rich |
Allan |
Sep 25 2004, 04:23 PM
I know (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) This sucks.
Allan |
Sep 25 2004, 04:32 PM
So any advise on replacement pistons and cylinders. Pelican wants $550.00 for a set of the Euro specs. Are the Japanese made ones on ebay crap or what?
bob91403 |
Sep 25 2004, 05:04 PM
Senior Member Group: Members Posts: 618 Joined: 15-September 04 From: Los Angeles, CA Member No.: 2,763 |
Just a suggestion. After your repair, before you bolt up your exhaust go to www.casperlabs.com/casperlabsinc/id1.html. They seem to have a very nice product that is well worth a look. The page takes forever to load. Be patient, it's worth it.
Cap'n Krusty |
Sep 25 2004, 05:24 PM
Crank grinding and case align boring are RARE in T4 motors. I can't remember a single case in 30+ years that needed boring, and there was a time when we were doing 3-4 a week. Same for the cranks. I still see old dead T4 motors with a jillion miles on 'em and standard cranks. In the case of a bad rod journal, just get another crank. In the case of an exploded motor, just get another one. Cam wear, on the other hand, is an ongoing problem. Be sure to buy a good quality cam and new lifters. Web Cam makes sets. HTH, The Cap'n
MattR |
Sep 25 2004, 05:33 PM
For pistons, you might want to consider going with 96mm pistons from aircooled.net. The set is 275 with rings last I checked. You have to get your cylinders bored too, but thats not tough, it looks like you're going to need it anyway.
watsonrx13 |
Sep 25 2004, 05:35 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
This is what the heads will look like after a rebuild.
Thanks Joe.... (IMG:style_emoticons/default/smilie_pokal.gif) Attached image(s) |
watsonrx13 |
Sep 25 2004, 05:37 PM
Lo-Fi Version | Time is now: 16th May 2024 - 01:29 AM |
