Karman body number |
OmaPossu |
Mar 26 2012, 02:37 PM
Member Group: Members Posts: 241 Joined: 4-October 09 From: Finland Member No.: 10,886 Region Association: Scandinavia |
In the floor of my friends 914:s rear trunk are two body numbers. Car is 1970 1,7 VIN 4702904415 and first sold in Germany, afterwards shipped to USA.
Numbers are (under one) 130734, last digit may be something else than 4, and top of it is new number 0719530. I thought only 6:s have that number in rear trunks floor? And why two numbers? |
Tom_T |
Mar 26 2012, 03:54 PM
All 914/4s & 914-6s had the Chassis numbers stamped both in the rear trunk floor & on the drivers front door jamb plate (upper box number - lower number is the OE color code) while at the Karmann plant, then the completed -6 shells were sent to Stuttgart for completion.
There should only be one number, and the two may indicate that a rust or accident damage repair was done where a part of the rear trunk from another 914 was welded in with it's chassis number intact - resulting in 2 conflicting chassis numbers. You can compare the two trunk numbers with the number on the Karmann plate on the driver door jamb as the correct one for your car (they should match), but if the Karmann plate is missing, then you'll need to research your 914's history to uncover which number was correct. |
sixerdon |
Mar 26 2012, 04:02 PM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
.......or, there was a factory error and Hans grabbed a /6 pan by mistake and then had to stamp in the chassis number for a /4.
Both numbers seem to relate to a Feb '70 time period. Where are these numbers located on the pan? (maybe there is a /6 out there with a missing trunk pan......) Don |
Gustl |
Mar 26 2012, 09:37 PM
914 enthusiast & historian Group: Members Posts: 11,494 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
All 914/4s & 914-6s had the Chassis numbers stamped both in the rear trunk floor & on the drivers front door jamb plate ... the 914-6 didn't have the number on the Karman plate the 914 had the number hammered in the reat trunk till lat MY'74 cars, then they got a little plate with the number in the fromt trunk instead of the rear trunk thing 130734 - is a body number of a 914-6 0719530 - is a body number of a 914 (IMG:style_emoticons/default/beerchug.gif) Gustl |
teemuki |
Mar 27 2012, 01:27 AM
Newbie Group: Members Posts: 2 Joined: 11-February 12 From: Finland Member No.: 14,117 Region Association: Europe |
Where are these numbers located on the pan? Hi all, both numbers are stamped to the center of the pan, close to the trunk latch. The car has been registererd with California licence 674 CRU (blue plate) in ยด1993 (might prove useful, should someone have access to car registration database or something like that) ...and as the wittiest of you might have guessed by now, I'm the current owner of the car in question (IMG:style_emoticons/default/smile.gif) |
Gustl |
Mar 27 2012, 05:56 AM
(IMG:style_emoticons/default/welcome.png) ... from the neighbourhood (at least globally speaking (IMG:style_emoticons/default/biggrin.gif) )
teemuki |
Mar 28 2012, 12:53 AM
pete000 |
Aug 11 2012, 12:48 AM
Is there a way to determine the month the car was built in as well as the year on the 914-6 chassis ?
Mine is Vin# 9140430131 and chassis #130189 From what I can find out on the internet the 1 is (Production body) 3 is (Karmann 914-6) 0 is (1970) and the 189 is the serial number. Is there now way to determine the month of build from any of the numbers on the 914-6?? |
sixerdon |
Aug 11 2012, 08:45 AM
Is there a way to determine the month the car was built in as well as the year on the 914-6 chassis ? Mine is Vin# 9140430131 and chassis #130189 From what I can find out on the internet the 1 is (Production body) 3 is (Karmann 914-6) 0 is (1970) and the 189 is the serial number. Is there now way to determine the month of build from any of the numbers on the 914-6?? Pete, I own #0137, 6 digits after yours. You are correct w/ #13,.......where 0189 is the Karmann chassis number for 1970 /6's. To answer your question,......no, these numbers do not indicate when the chassis was built like the /4's do. If you did not have a DOT sticker on your door jamb, you would have to use the VIN Database to compare the chassis numbers on other /6's and work out the math. Yours was built in Jan '70 (as was mine) and was one of the first 50 or so brought into the US. BTW. '71 /6's have a 7 digit number. Don |
pete000 |
Aug 11 2012, 09:52 AM
QUOTE Yours was built in Jan '70 (as was mine) and was one of the first 50 or so brought into the US. Don Wow very cool ! Our cars were in sight of each other rolling down the line ! Yours would not recognize mine today because of a color change from yellow to white and the addition of M471 steel arches. I figured it had to be one of the first to roll out in 1/70 I am having a new door dot decal made up and was just hoping to get the month correct. Roughly how many sixes did they make a month? |
sixerdon |
Aug 11 2012, 04:43 PM
QUOTE Yours was built in Jan '70 (as was mine) and was one of the first 50 or so brought into the US. Don Wow very cool ! Our cars were in sight of each other rolling down the line ! Yours would not recognize mine today because of a color change from yellow to white and the addition of M471 steel arches. I figured it had to be one of the first to roll out in 1/70 I am having a new door dot decal made up and was just hoping to get the month correct. Roughly how many sixes did they make a month? Given what little "d" info there is in the database, my "guesstimate" would be less than 100 for 01/70. Then for 02/70 through 06/70 they seemed to average 400-500/mo before trailing off drastically in 07/70. At that time, Porsche KG probably looked at their data and determined they weren't selling as hoped and so went on their summer "holiday". The rest is history. I have hoped more /6 owners would list their DOT date if it were available. Don |
gms |
Nov 11 2012, 11:43 PM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
In the floor of my friends 914:s rear trunk are two body numbers. Car is 1970 1,7 VIN 4702904415 and first sold in Germany, afterwards shipped to USA. Numbers are (under one) 130734, last digit may be something else than 4, and top of it is new number 0719530. I thought only 6:s have that number in rear trunks floor? And why two numbers? The next question I would ask is does it have holes for the -6 oil tank and does it have a center dash vent? |
OmaPossu |
Nov 12 2012, 11:52 AM
No oil tank holes and there is center dash vent.
sbsix |
Nov 12 2012, 04:13 PM
only the lead dog enjoys a change in scenery... Group: Members Posts: 449 Joined: 10-January 12 From: Santa Barbara, CA Member No.: 13,990 Region Association: Southern California |
QUOTE Yours was built in Jan '70 (as was mine) and was one of the first 50 or so brought into the US. Don Wow very cool ! Our cars were in sight of each other rolling down the line ! Yours would not recognize mine today because of a color change from yellow to white and the addition of M471 steel arches. I figured it had to be one of the first to roll out in 1/70 I am having a new door dot decal made up and was just hoping to get the month correct. Roughly how many sixes did they make a month? Given what little "d" info there is in the database, my "guesstimate" would be less than 100 for 01/70. Then for 02/70 through 06/70 they seemed to average 400-500/mo before trailing off drastically in 07/70. At that time, Porsche KG probably looked at their data and determined they weren't selling as hoped and so went on their summer "holiday". The rest is history. I have hoped more /6 owners would list their DOT date if it were available. Don my '70 six 9140432347 has a build date of 06/70 and chassis #132391. It took me awhile to target the build date since it's a euro version and didn't come with a door jamb sticker. If it wasn't for the internet I would never would have been able to do the research. |
gms |
Nov 12 2012, 11:16 PM
puffinator |
Dec 16 2015, 08:30 AM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 4th May 2024 - 08:59 AM |
