My clutch is freaky..., help |
Trekkor |
Sep 29 2004, 12:27 AM
It works really good most always.
When I really hammer it, like at a/x, it starts to slip during the last runs. When I do the spirited thing (IMG:style_emoticons/default/unsure.gif) , again slippy. When it cools off, all's good in my 914 world. I'll put a terry cable in soon and this clutch is 500 miles old, max, 911 six spring. Last clutch did it too, but it was oily. Replaced the rear main seal. I just need to run 3 more events and then it's SIX o' clock. KT |
Sep 29 2004, 09:50 AM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
well, if the old one was oily, then the new one might be oily too!
i assume you cleaned everything when you had it apart. have you checked for leaky main shaft seal after you replaced it? did you resurface the flywheel? new pressure plate? is the pilot bearing in the right location? is the clutch adjusted right? how far from the top does it dis-engage? (IMG:style_emoticons/default/idea.gif) Andy |
Andyrew |
Sep 29 2004, 09:55 AM
I had clutch problems till I went with the v8 system..
I recomend that! (IMG:style_emoticons/default/cool.gif) I think my problem was a bad clutch.. but maybe you put the main seal in wrong and its still leaking? Andrew |
McMark |
Sep 29 2004, 09:58 AM
I can't remember if the clutch cable was double nutted or not. Check that first.
sgomes |
Sep 29 2004, 01:53 PM
Electric Member Group: Members Posts: 815 Joined: 6-May 04 From: Campbell, CA Member No.: 2,029 |
QUOTE(SirAndy @ Sep 29 2004, 07:50 AM) is the pilot bearing in the right location? Hey Andy, Just curious what effect does this have? And what is the "right" location? |
Sep 29 2004, 01:58 PM
QUOTE(sgomes @ Sep 29 2004, 12:53 PM) Hey Andy, Just curious what effect does this have? And what is the "right" location? right location is in the flywheel and *not* on the crank. effect? look at my avatar ... (IMG:style_emoticons/default/sad.gif) the main shaft won't have any support, it starts to "wobble", you'll spill a gallon of tranny oil all over your car and the bearings inside the tranny that hold the main shaft will say "bye bye". and, if you're really lucky, it'll eat your case around the main bearings as well ... not bad for a $5 part in the wrong place, huh? (IMG:style_emoticons/default/unsure.gif) Andy |
Brad Roberts |
Sep 29 2004, 02:24 PM
Hows your pedal assembly Trekkor ??
B |
Gint |
Sep 29 2004, 03:12 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
QUOTE(SirAndy) effect? look at my avatar ... Riiiigghghgtttt. You avatar looks like ass. |
Trekkor |
Sep 29 2004, 03:34 PM
QUOTE(Brad Roberts @ Sep 29 2004, 01:24 PM) Hows your pedal assembly Trekkor ?? Felt good, bronze bushed. remember the stretching metal sound it made? I'll change out the cable and check back after it in and adjusted. KT |
Trekkor |
Oct 4 2004, 07:34 PM
Mark and I replaced the old cable with the Terry and all is right again. I will live happily ever after. (IMG:style_emoticons/default/smile.gif)
Terry cables for everyone (IMG:style_emoticons/default/beer.gif) KT |
McMark |
Oct 4 2004, 07:37 PM
And then my monster motor stomped all over his tired stock 2.0. (IMG:style_emoticons/default/biggrin.gif) I'm eatin' them up left and right. First Randy and now Trekkor.
Cap'n Krusty |
Oct 4 2004, 07:40 PM
Coupla thoughts ............ ALWAYS replace the flywheel o-ring. ALWAYS. If you hears a metallic "stretchy" noise, a GOOD look at the clutch cable tube through the tunnell is in order ........................ The Cap'n
Trekkor |
Oct 4 2004, 07:50 PM
QUOTE(markd@mac.com @ Oct 4 2004, 06:37 PM) And then my monster motor stomped all over his tired stock 2.0. (IMG:style_emoticons/default/biggrin.gif) I'm eatin' them up left and right. First Randy and now Trekkor. (IMG:style_emoticons/default/chowtime.gif) You'll see....You'll see KT |
bondo |
Oct 4 2004, 09:25 PM
QUOTE(Cap'n Krusty @ Oct 4 2004, 06:40 PM) Coupla thoughts ............ ALWAYS replace the flywheel o-ring. ALWAYS. If you hears a metallic "stretchy" noise, a GOOD look at the clutch cable tube through the tunnell is in order ........................ The Cap'n Flywheel o-ring? Where's that? |
McMark |
Oct 4 2004, 10:21 PM
In the flywheel where the end of the crank slides in. In other words, on the crankshaft side of the five flywheel bolts.
Lo-Fi Version | Time is now: 18th May 2024 - 11:23 PM |
