FS, too many parts. |
TheCabinetmaker |
Apr 9 2012, 09:35 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
No, but I may know where to get a replacement. I'm checking now.
ThePaintedMan |
Apr 9 2012, 04:01 PM
How about all of the parts for the thermostat assembly? I think that means the thermostat itself, cable, roller, bracket, nut and roller bolt. This would be for a 1973 1.7, if it matters.
Also, I am in need of a complete seat belt bolt set (but mostly just the lower 4). This is an odd part, but I also need just 1 washer that sandwiches the rubber bushings on the rear shocks. Have any rusty rear valences? Thanks! |
76-914 |
Apr 10 2012, 07:41 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
How much of it do you need Kent? I need the mechanism w/ belt for both sides. Don't need bolts or misc hardware. L side won't retract w/o some nursing and when retracted the R side sounds like it's climaxing. (IMG:style_emoticons/default/lol-2.gif) |
TheCabinetmaker |
Apr 10 2012, 07:53 AM
How much of it do you need Kent? I need the mechanism w/ belt for both sides. Don't need bolts or misc hardware. L side won't retract w/o some nursing and when retracted the R side sounds like it's climaxing. (IMG:style_emoticons/default/lol-2.gif) I'll look for the best I can find. I'll pm you later. |
76-914 |
Apr 11 2012, 08:13 AM
How much of it do you need Kent? I need the mechanism w/ belt for both sides. Don't need bolts or misc hardware. L side won't retract w/o some nursing and when retracted the R side sounds like it's climaxing. (IMG:style_emoticons/default/lol-2.gif) I'll look for the best I can find. I'll pm you later. Thx, Take your time. |
ThePaintedMan |
Apr 11 2012, 09:17 AM
How about all of the parts for the thermostat assembly? I think that means the thermostat itself, cable, roller, bracket, nut and roller bolt. This would be for a 1973 1.7, if it matters. Also, I am in need of a complete seat belt bolt set (but mostly just the lower 4). This is an odd part, but I also need just 1 washer that sandwiches the rubber bushings on the rear shocks. Have any rusty rear valences? Thanks! ? |
TheCabinetmaker |
Apr 11 2012, 09:27 AM
Damn George. Don't know how you slipped by me. Sorry.
I have all the peices for the thermstat except a good bellows. Wait. I have a car I haven't checked that. The washer that goes on top of the top rubber under the nut? If so I have it I have everything esle. How rusty of a valance dou want? LOL |
ThePaintedMan |
Apr 11 2012, 09:25 PM
Damn George. Don't know how you slipped by me. Sorry. I have all the peices for the thermstat except a good bellows. Wait. I have a car I haven't checked that. The washer that goes on top of the top rubber under the nut? If so I have it I have everything esle. How rusty of a valance dou want? LOL Thermostat: Yeah, I need everything that would normally come with the thermostat assembly. I have the flaps, so basically everything down from that. Working bellows would be great. Shock washer: No, I need the ones at the bottom. They sandwich the rubber bushing inside the bottom of the shock mount. There should be two. My dumbass lost one. Valence: As far as a valence, I'm just looking for something cheap to use to repair and/or cut up. Eventually I'd like to make a fiberglass mold from it. Just enough to be able to slap on the car for now. Thanks for not forgetting me! Oooh! One more thing: Do any of your cars have decent door hinges? I just need two hinge pins, if you feel like knocking them out. I would rather not pay the $15 a piece from PP. |
TheCabinetmaker |
Apr 12 2012, 11:57 AM
George, I have the pins. As for the washers, There is only one per shock. The bolt head acts as the washer on the inboard of the shock. The washer goes between the shock and trailng arm mount.
ThePaintedMan |
Apr 13 2012, 04:53 PM
Okay Curt. I'll take a picture of the shock as soon as I can to clarify what I'm talking about. Think we're speaking a different language at the moment (IMG:style_emoticons/default/smile.gif)
TheCabinetmaker |
Apr 13 2012, 05:03 PM
Yep, a picture is still worth a thousand words.
scoobykvn |
Apr 14 2012, 06:27 PM
Member Group: Members Posts: 142 Joined: 6-July 06 From: columbus, ohio Member No.: 6,388 Region Association: Upper MidWest |
Any weather stripping? In particular the triangle window seal and the 3 sided seal that goes around the windshield to seal the targa on the front and Windows on the side. How about the aluminum track that holds the outer window scraper seal for an early model? Need one for each side.
TheCabinetmaker |
Apr 14 2012, 07:02 PM
I'm striking out on all of that. Sorry
euro911 |
Apr 14 2012, 07:58 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Any weather stripping? In particular the triangle window seal and the 3 sided seal that goes around the windshield to seal the targa on the front and Windows on the side. How about the aluminum track that holds the outer window scraper seal for an early model? Need one for each side. Mike (schantzMD) may still have a set of the wind-wing glass seals able (see item (G), and front targa seals (see item (S) A, B & C) ... Click hereNew repro aluminum window scraper tracks ... Click here |
scoobykvn |
Apr 14 2012, 08:12 PM
Any weather stripping? In particular the triangle window seal and the 3 sided seal that goes around the windshield to seal the targa on the front and Windows on the side. How about the aluminum track that holds the outer window scraper seal for an early model? Need one for each side. Mike (schantzMD) may still have a set of the wind-wing glass seals able (see item (G), and front targa seals (see item (S) A, B & C) ... Click hereNew repro aluminum window scraper tracks ... Click here Thanks, I will talk to him. I already posted on the scraper tracks thread. Waiting on a reply. Just thought I would keep looking. |
TheCabinetmaker |
Apr 14 2012, 08:25 PM
I have the scraper track, just not for the early cars.
TheCabinetmaker |
Apr 16 2012, 08:20 AM
Okay Curt. I'll take a picture of the shock as soon as I can to clarify what I'm talking about. Think we're speaking a different language at the moment (IMG:style_emoticons/default/smile.gif) Does this pic show what you need? |
timothy_nd28 |
Apr 16 2012, 02:20 PM
I received a box of parts this morning. Everything looks great!
Thanks (IMG:style_emoticons/default/beerchug.gif) |
TheCabinetmaker |
Apr 16 2012, 02:22 PM
Thank you, Tim.
TheCabinetmaker |
Apr 18 2012, 01:07 PM
bump
Lo-Fi Version | Time is now: 17th June 2024 - 06:08 AM |
