> sideshift engine beam with tailshift tranny?, can i use a sideshift engine beam with a tailshift transimission?
1973_1.7
post Apr 5 2012, 02:31 PM
Region Association: Europe
I know i cant use a tailshift engine beam with sideshift transmission, but is it possible the other way? Sideshift engine beam with tailshifte transmission?
post Apr 5 2012, 02:34 PM
Resident German
QUOTE(1973_1.7 @ Apr 5 2012, 01:31 PM) *
I'm pretty sure the shift-rod won't fit around the engine mount bar ...
1973_1.7
post Apr 5 2012, 04:13 PM
The problem is that I have a freshly rebuilt tailshift transmission without the linkage, and the linkage is difficult to source in Norway. I have to get shipped from somewhere abroad, and the shipping will be much cheaper without the engine bar.
So it would be great to know if I can use my engine bar or not, that would save me alot in shipping as they are big and heavy (IMG:style_emoticons/default/smile.gif)
post Apr 5 2012, 04:34 PM
Resident German
QUOTE(1973_1.7 @ Apr 5 2012, 03:13 PM) *
Do you have a spare sideshifter? You can convert your tailshifter to a sideshifter ...
1973_1.7
post Apr 5 2012, 04:58 PM
I have a spare sideshifter, I opened it up and changed the synchro bands but I cant get it to shift properly and I am lacking 4th and 5th gear, so the tailshifter was supposed to be a quick fix until I get the sideshifter opened up and adjusted properly. What needs to be changed to convert the sideshifter?
Dr Evil
post Apr 5 2012, 10:04 PM
Send me your transmission!
Did you get my DVD? It will cover all of this.
To your original question, no. The front mounts on the engine to the bar are totally different.
Dr Evil
post Apr 5 2012, 10:05 PM
By the way, it would be pretty easy to make a tail shift mount bar, but not a side shift one.
1973_1.7
post Apr 6 2012, 02:03 AM
Hi Dr. evil , I have not received your dvd yet but some times the mail takes a little time.
I also have the engine mounts for a tailshifter, so its just the engine mount bar and the linakge i am missing. But the tailshift linkage does not clear the engine mount bar from a sideshifter?
Dr Evil
post Apr 6 2012, 06:32 AM
The mounts from the engine to the tail shift bar are different and wont work on the side shift bar. Honestly, I can not remember if the tail shift linkage will work with a side shift bar as this is not a common conversion. I have seen a side shift linkage with a tail shift bar and that does not work.
Again, if you have all the bits except for the mount bar, the tail shift bar is easy to make.
- Lo-Fi Version Time is now: 30th July 2025 - 11:51 AM
