some extra parts for sale, efi harness steering wheel 009 dist. rear calipers |
drdave427 |
Apr 5 2012, 08:57 PM
Newbie Group: Members Posts: 31 Joined: 26-March 12 From: East TN Member No.: 14,306 Region Association: South East States |
I have some extra stuff some of you might need -- Not sure what it is worth so I'll price it and you can make offers. Might work out some trades too - I want a CHT gauge & sender(under 14mm plug type) and I need a nice drivers door panel in black. I wanted to show them here before putting them on fleabay.
009 distributor I removed for an electronic SVDA unit. Worked good. Cap and wires available if you want them. $75.00 Calipers were extras I got with car - rubber looks good but no hardware they are dual bleeders. $75.00 EFI harness I have had for 15 years - real good shape except for one spot. I tried to show the worst place and it isn't bad. I am not sure what year it fits - I think 2.0 ? $75.00 Steering wheel in pretty good shape except for horn section metal edge. Again , don't know what year , stitching looks really good - You guessed it - $75.00 Prices don't include shipping unless you con me into it - probably at worst another $15 - $20 . Thanks for looking. Again make me an offer if you feel I have this stuff priced unreasonably - I have larger photos I can email if you need them. Also have a brand new 23 mm master cylinder - $100.00 Attached thumbnail(s) |
sportlicherFahrer |
Apr 5 2012, 09:27 PM
Nothing to see here. Group: Members Posts: 1,079 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Just a heads up. Looks like you have a 1.8L L-Jet FI harness. Not sure if there was a difference from '74-'75. Hope that helps a little...
drdave427 |
Apr 5 2012, 09:36 PM
Just a heads up. Looks like you have a 1.8L L-Jet FI harness. Not sure if there was a difference from '74-'75. Hope that helps a little... Thanks -- All knowledge is good !! I had no idea what engine it was for. I had a 72 that had a 2.0 in it years ago and the harness was in a box of extra stuff i got with that car. Thanks for the info !! |
cpfoster |
Apr 5 2012, 09:57 PM
Newbie Group: Members Posts: 9 Joined: 11-May 10 From: Washington, DC Member No.: 11,718 Region Association: None |
Just a heads up. Looks like you have a 1.8L L-Jet FI harness. Not sure if there was a difference from '74-'75. Hope that helps a little... Thanks -- All knowledge is good !! I had no idea what engine it was for. I had a 72 that had a 2.0 in it years ago and the harness was in a box of extra stuff i got with that car. Thanks for the info !! Dr. Dave - I will take that steering wheel. Private Message sent. |
914runnow |
Apr 5 2012, 11:12 PM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
The black plug has either 6 or 7 pins on the harness..
6 for 74 1.8..... 7 for 1.8 75...there yah go.. Yepperz CW,s can be 1.8 nerd, (IMG:style_emoticons/default/rolleyes.gif) z too..! |
drdave427 |
Apr 6 2012, 05:07 AM
The black plug has either 6 or 7 pins on the harness.. 6 for 74 1.8..... 7 for 1.8 75...there yah go.. Yepperz CW,s can be 1.8 nerd, (IMG:style_emoticons/default/rolleyes.gif) z too..! Not sure which black plug to look at -- the big black connector that hooks to the ECM has 19 connectors (pins) in it. |
poorsche914 |
Apr 6 2012, 07:56 AM
T4 Supercharged Group: Members Posts: 3,090 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Dave,
I have a couple '73-'74 door panels. First one has best vinyl but the back side is warped. Probably would install and flatten out OK. Second one is flatter but has a chunk out of it along lower edge. Vinyl is in good shape. Both of them have a 2-3" cut along the bottom edge of the upper pad section just above where the window winder is. steve |
drdave427 |
Apr 6 2012, 03:52 PM
Dave, I have a couple '73-'74 door panels. First one has best vinyl but the back side is warped. Probably would install and flatten out OK. Second one is flatter but has a chunk out of it along lower edge. Vinyl is in good shape. Both of them have a 2-3" cut along the bottom edge of the upper pad section just above where the window winder is. steve The first one doesn't look too bad -- how much are you asking for it ?? |
drdave427 |
Apr 7 2012, 11:37 AM
Steering wheel sold
JeffBowlsby |
Apr 7 2012, 11:47 AM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Please don't be offended but with all those broken wires and such that 1.8L FI harness may have a few good parts is all, it is not worth even repairing. Would you accept $15 for it with shipping to 94583?
Its parts may help another 1.8L to live. (IMG:style_emoticons/default/smile.gif) |
drdave427 |
Apr 7 2012, 07:08 PM
Please don't be offended but with all those broken wires and such that 1.8L FI harness may have a few good parts is all, it is not worth even repairing. Would you accept $15 for it with shipping to 94583? Its parts may help another 1.8L to live. (IMG:style_emoticons/default/smile.gif) There are no "broken wires" that I know of -- only 3 ends on the whole harness have a crack in the insulation. I have a $60 offer on it right now - if it falls through I will let you know. Not offended at all ! |
poorsche914 |
Apr 8 2012, 11:58 AM
drdave427 |
Apr 11 2012, 06:07 PM
(IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif)
Added 23mm master cylinder |
Lo-Fi Version | Time is now: 16th May 2024 - 11:02 PM |
