Help with a headlight issue., Why don't they work? |
B2524 |
Apr 7 2012, 08:53 PM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
I have a 72 that I just got.
When you turn on the headlights they don't turn on or come up. The parking lights work as they should. So I turned the knob on the motors and got them to come up manually. It was obvious from the dirt they had not been up in years. The light switch was in the on position when I did this. When I shut them off they went down as they should. The light bulbs were never lit. They Did not come up after that, except manually. Fuses are all good. I have swapped relays around on the fuse panel but that didn't hep. I'm not sure which relay on the panel is for the motors. Any ideas? Thanks |
Prospectfarms |
Apr 7 2012, 09:29 PM
Member Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest |
That was a good diagnostic idea. Wish I'd thought of it a couple of weeks ago. It makes sense (to me) that what you described would happen if one part of your light switch is working and an other is not.
Here's a link that might help.How the headlight lamp/motor circuit works Per Cap'n Krusty: I also suggest that you examine a wire diagram for you year. An assortment of diagrams can be found at the Pelican Parts website. |
1973-914-2L |
Apr 7 2012, 11:48 PM
914 newb ... Group: Members Posts: 93 Joined: 4-March 12 From: Stockton, Nor-Cal Member No.: 14,217 Region Association: Central California |
Not sure if the 72 is the same as my 73 but I have another relay just below and to the inside of the head light motor .. if yours has the cover in the inner pull those .. I think its on yours also ...
Prospectfarms |
Apr 8 2012, 04:48 AM
'72 the same.... motor relay's up front next to HL assemblies, bright/dim illumination relay on fuse panel. (IMG:http://www.914world.com/bbs2/uploads_offsite/bowlsby.net-12801-1333882134.1.jpg)
Fuse 1-4 energizes the lights. Fuse 12 power's the motors. Power travels from switch to fuse to relay (on some circuits) but the light fuses are actually powered from the front relay's |
Lennies914 |
Apr 8 2012, 08:54 AM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Is the key on?
Lo-Fi Version | Time is now: 28th May 2024 - 04:43 PM |
