I have a 72 that I just got.
When you turn on the headlights they don't turn on or come up.
The parking lights work as they should.
So I turned the knob on the motors and got them to come up manually. It was obvious from the dirt they had not been up in years.
The light switch was in the on position when I did this.
When I shut them off they went down as they should. The light bulbs were never lit.
They Did not come up after that, except manually.
Fuses are all good.
I have swapped relays around on the fuse panel but that didn't hep. I'm not sure which relay on the panel is for the motors.
Any ideas?
Thanks
