rear brake question, missing interior adjuster, now what?! help! |
tat2dphreak |
Oct 2 2004, 12:51 PM
ok, today I am working on installing new rear pads and I pulled off the caliper to inspect... the was no aluminum adjuster cap on(no bigie, I have extras) but when I look inside, there is no adjuster! it looks like it is broken off, though I can't REALLY see in there, but it feels flat to the allen wrench...
I pulled off the other, same thing... what gives? what do I do now? will a big clamp work to get the pads in? |
McMark |
Oct 2 2004, 12:57 PM
The inners have a small geared piece that can fall out if the cap is not on. Nothin is broken off, you just need to replace the piece. But you can't just pry the piston back into place. You must use the adjuster. So you're stuck until you get at least one.
tat2dphreak |
Oct 2 2004, 12:58 PM
who has them?
PP? |
Aaron Cox |
Oct 2 2004, 01:14 PM
im sure AA has the LAST ONE! (IMG:style_emoticons/default/laugh.gif)
tat2dphreak |
Oct 2 2004, 01:15 PM
LOL, I'm sure they do!
I have a good extra set of front brakes...that I COULD use on the back... but I need the e-brake to pass inspection |
anthony |
Oct 2 2004, 06:35 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Are both caps and adjusters missing? You can use the one from the other side if only one is missing.
To do the adjusting I also had to buy a 4mm hex on a socket with an extension that that long enough to go through the trailing arm. |
tat2dphreak |
Oct 3 2004, 02:50 PM
both were missing, but I, luckily remember I had an old rusted set off a previous 914... the 1 part that was usable was the adjusters... I had completely forgot about them, and didn't know they came out so easily!
1 more project down 999,999+ to go thanks guys!! (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 07:50 PM |
