Rear window, Removal |
glens67 |
Apr 12 2012, 05:10 PM
Newbie Group: Members Posts: 35 Joined: 13-March 10 From: Middleton, ID Member No.: 11,462 Region Association: Rocky Mountains |
OK the rollbar pading is giving me some problems.
I have removed the top screws and under screws. It wont budge. The side pads have coat hooks. How do you get them off? Do the side pads have to come off before the top pad? Thanks Glen |
JamesM |
Apr 12 2012, 05:13 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
OK the rollbar pading is giving me some problems. I have removed the top screws and under screws. It wont budge. The side pads have coat hooks. How do you get them off? Do the side pads have to come off before the top pad? Thanks Glen Plastic slides off the coat hooks and there is a screw under them. Top pad probably still has some screws hiding, they always do. |
glens67 |
Apr 12 2012, 05:16 PM
OK the rollbar pading is giving me some problems. I have removed the top screws and under screws. It wont budge. The side pads have coat hooks. How do you get them off? Do the side pads have to come off before the top pad? Thanks Glen Plastic slides off the coat hooks and there is a screw under them. Top pad probably still has some screws hiding, they always do. Push the hook up? I will look again for the umpteenth time Need more Beer. (IMG:style_emoticons/default/beer.gif) Thanks |
914itis |
Apr 12 2012, 05:17 PM
Yep u need to take off the size pads and the glue that holds the window.
Valy |
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
As far as I remember, the rear window will not fit in with the side or top pads on. You need to remove all of them anyway.
The hooks have plastic covers. Remove them upwards and you'll see a screw under. You also need to take out the seat belts Then the backpack will slide DOWN (remove the bottom screws first). There are some hooks at the top of it that hold it in place. |
TheCabinetmaker |
Apr 12 2012, 05:20 PM
if I recall correctly, the sides must come off and the backpad. The top pad can stay in place.the coat hook cover pulls off to reveal a screw
glens67 |
Apr 12 2012, 05:58 PM
Apr 12 2012, 06:17 PM
Don't forget the little screws where the targa latches are. My car didn't have them, but they sure made the next car I worked on (I think it was Jenny's orange car?) quite difficult.
--DD |
glens67 |
Apr 12 2012, 11:18 PM
Got the pads off. Thanks
Window was completely loose, Butal sealant came out in one long piece. THANKS Glen |
Lo-Fi Version | Time is now: 19th May 2024 - 07:50 AM |
